Power Door Locks
Old Mar 13, 2010 | 11:49 AM
DadNSonF350's Avatar
DadNSonF350
Power Door Locks
I am trying to put an aftermarket remote lock system in our 1995 crew cab. The instructions say if the system uses positive power then run hot wires from relays to the door lock switches. If it is a negative system then use the negative leads from the aftermarket controller to the switches.
The problem is when I use positive power to the switches it acts like a dead short and burns up the wires. When I send a ground signal it does nothing. When the system works by pushing the button it uses 12v positive but when I put 12v positive there all I get is buzzing actuator and smoke.
Surely someone has installed aftermarket keyless entry on a PSD.
Please help I have tried searching the forum but can't find my answer.
Thanks,
Allen
Old Mar 13, 2010 | 02:36 PM
Hussler's Avatar
Hussler
Might not work with the aftermarket. Hard to tell without seeing the instructions. Both sides of the motor(s) are at ground when switch is idle. Switching to lock/unlock applies voltage to the motor and reverses polarity depending on switch position.
If you have power locks then you might already have the key-less entry module under the dash. If so then you just need to get the transmitter and activate it.
Old Mar 13, 2010 | 04:05 PM
DRRXR's Avatar
DRRXR
Could not find your model but I was close.
Also I figured that some of our other FTE folks may like the second link. Good wiring info to share.
First link
1997 -1998 Ford F Series Super Duty Vehicle Wiring Chart and Diagram
Second Link
Ford Car Alarm Wiring Information
Old Mar 13, 2010 | 04:13 PM
DRRXR's Avatar
DRRXR
Here is another
Mo INFO
Technical Wiring Diagrams
Old Mar 13, 2010 | 04:32 PM
DadNSonF350
You guys came through again thanks.
Old Mar 13, 2010 | 06:08 PM
DRRXR's Avatar
DRRXR
So did you get it finished?
Old Mar 13, 2010 | 07:05 PM
DadNSonF350
Finished now, works great, my son is so happy.
Thanks from us both.
Allen
ryankerr
Electrical Systems/Wiring
Mar 5, 2014 10:06 AM
Mr.ford
1997 - 2003 F150
Sep 9, 2012 05:59 PM
highboy75
Nov 9, 2007 02:54 PM
