Down in the Valley
Old Mar 12, 2010 | 11:12 PM
Jaaaaaaackman's Avatar
Jaaaaaaackman
Down in the Valley
Something is leaking diesel down in the valley , the fuel works its way over to the starter side on its way to the ground.......... I am planning to just go down to the Valley and seal up everything I see, any suggestions? Ive never been down in the Valley not sure what Ill find hope it simple, my truck is an 81,000 mile virgin besides a bad DMF this is the first real problem ........ Any thoughts or ideas????????
Old Mar 13, 2010 | 03:37 AM
michaloco's Avatar
michaloco
European Enthusiast
at my truck it was the vacuum switch on the drivers side on the fuel bowl. i've learned that it's a common problem. start the truck and try to see where it's leaking from.
hope this helps.
Old Mar 13, 2010 | 03:45 AM
michaloco's Avatar
michaloco
European Enthusiast
found a picture. thanks to cuda_jim for posting it in another thread
is the red wired thing near the top of the bowl
Old Mar 13, 2010 | 06:31 AM
Jaaaaaaackman
Michael Thanks thats a good pic and thanks to Cuda Jim too. So far all I can see is the fuel way down deep the filter area is clean and dry my plan is to re do evertthing do there so since its been 15 years and zero leaks down there I might as well do everything and get 15 more years of good service . Today is a wet rainny day so looks like it will have to wait for a better day.
I am open to any suggestions and ideas.
Thanks Jack
Old Feb 26, 2012 | 01:51 PM
Jaaaaaaackman
hope this helps.
Hey Mike that pic disappeared but do you know what that vacuum type switch part does?
My switch is leaking fuel at a good clip trying to see if Auto Z has them in stock but I don't know what its called.
Old Feb 26, 2012 | 01:59 PM
blageurt's Avatar
blageurt
Commonly refered to as a fuel restriction sensor also...I removed it and just plugged mine with a 50 cent plug .... did not feel like paying 50 bucks or so for a POS that will just leak again.....
Old Feb 26, 2012 | 02:04 PM
Jaaaaaaackman
Yep thats what I intend to do , the wire has been disconnected for years.
Thanks for the reply
Old Feb 26, 2012 | 07:29 PM
Oldsmoky92's Avatar
Oldsmoky92
I pluggeg it as well
Old Feb 26, 2012 | 07:53 PM
fordpride's Avatar
fordpride
What size plus did y'all use mines leaking again for the fourth time
Old Feb 26, 2012 | 08:37 PM
Jaaaaaaackman
1/8th inch pipe thread in brass at AutoZone 2.99
Old Feb 26, 2012 | 08:55 PM
fordpride's Avatar
fordpride
Kool thanks.
Old Feb 26, 2012 | 09:22 PM
Oldsmoky92's Avatar
Oldsmoky92
Yep. I still have a leak though.. I think its the pump, darn things just dont last. I need to mop up the fuel and try to find the leak, its so small I keep putting it off but I need to fix it at 4 plus a gallon.
Old Feb 27, 2012 | 08:00 AM
Awitte58's Avatar
Awitte58
81k miles? Lookin to sell? lol
sorry O/T
Old Feb 27, 2012 | 04:24 PM
Jaaaaaaackman
sorry O/T
Yes I'll sell it, but its not what you probably are thinking, actually it an in town work truck low miles for its age but very very well worked and its showing its age in a bad way (rust)
sowaxeman
Apr 14, 2015 09:48 AM
Dodge/Cummins
Mar 7, 2013 10:46 PM
BENG0924
Jan 7, 2009 09:40 AM
BioNate
Jul 23, 2007 10:59 AM
adamant0
Dec 19, 2006 08:01 PM
