1964 F-250 wheel hub help
Hey all its been awhile since I said hi. So, HI..... Well im doing the front end on the old mans 64 F250 and I had the king pin bushings reamed and new tie rod ends new spring bushings new everything . Hes gonna drive from the central valley of CA to Washington state and maybe a trip to Alaska so We wanted a good solid front end under her. When I took the hubs off the left seal was gone. Further inspection of the hub revealed the inner race was just spinning in the hub. I was hoping that a new race would solve this but, no luck.....My question is this ive tried ALL.... the local parts houses and the salvage yards with no luck. They say its to OLD. Ive also tried LMC, sacramento vintage ford, and so on.Is the any years that will interchange? Im going to the local pick n pull but my hopes are low for this year of truck. they are awsome trucks but they are getting VERY hard to find parts for. My 66 f100 is alot easier to score parts for. This way i can look for other years when i go tomorrow. Thank you for your help
1964 F250 4WD
I was hoping that a new race would solve this but, no luck.....My question is this ive tried ALL...the local parts houses and the salvage yards with no luck.
They say its too OLD. Ive also tried LMC, sacramento vintage ford, and so on. Is the any years that will interchange?
There are two different hub & drums used on a 1964 F250 4WD. The difference is with the hubs, as the front brakes are the same size (12 1/8" x 2").
What hub the truck has...depends on what the front axle's weight capacity is.
B9TZ1102A .. Hub & Drum Assy / Use with 3,000 lb. front axle / Obsolete
Fits: 1959/68 F250 4WD / 1969 F250 4WD before serial number F70,001.
BOB ALLEN FORD in Overland Park KS has ONE = 800-676-0675.
No other Ford Dealer, no obsolete parts vendor has any.
C1TZ1102A .. Hub & Drum Assy / Use with 3,500 lb. front axle / Obsolete
Fits: 1961/68 F250 4WD / 1969 F250 4WD before serial number F70,001.
No Ford Dealer or obsolete parts vendor has any.
If you are unaware of what the front axle's weight capacity is, I may be able to tell you what it is.
I need the 3 digit AXLE code found on the Warranty Plate.
IF the Warranty Plate AXLE code is only 2 digits, I need the code off the front axle's ID tag.
Ford did not sell the front hub by itself, it was only furnished with the brake drum.
I dunno why I assumed it was 4WD, maybe...because you didn't say it was 2WD.
The same thing applies here, the hub was only furnished with the drum.
B7TZ1102B .. Hub & Drum Assy / Obsolete
Fits: 1957/64 F250 2WD
GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
No Ford Dealer, no other obsolete parts vendor has any.
Welcome to FTE
Ford did not sell the hub by itself. It was only furnished with the brake drum.
C6TZ1102E (replaced: C6TZ1102B, C4TZ1102A, C4TZ1104B) .. Hub & Drum Assy / Obsolete / Fits: 1964/67 F100 2WD.
You might contact FTE members: garbz2 or Bill W or camperspecial65 to see if they have any used parts.
Welcome to FTE
fajitamondays
06-30-2017 09:11 AM
1966f250
10-11-2016 02:33 PM
AKHunter93
35
11-09-2015 09:05 AM
