New carb ideas?
Old Mar 15, 2010 | 08:03 AM
unibody62's Avatar
unibody62
Originally Posted by charliemccraney
The 4100 is a good carb, too. In dyno testing 4v carbs on the Y, it was found that the 4100 may actually work out best for a street Y.
When I started looking on Ebay for a 4100, they are listed for a big blocks and rated at 600cfm. So that seems to conflict with what most have said about the max cfm on a stock Y. I guess as long as my final choice doesn't cause major problems I'll be happy.
Originally Posted by flipklos
Another option is to buy a teapot. I seen one on ebay the other day for $50. You would have to rebuild it to run it though. There are some drawbacks to the holley teapots but if you are just setting it on a stock engine in a vehicle you only drive casualy I dont see them being an issue.
I actually bought a teapot initially, then started reading some negative things about it and decided to just rebuild it and sell it. I also got a good deal on and Edelbrock (1405 I think), but I opted to sell that after I found out that it would not bolt right up. After reading feedback here from you all, it sounds like that was probably a good decision. I guess one of the main reasons I am looking for a slightly newer carb is because of technology advances to make it a more reliable and more fuel efficient. Efficiency won't make a big difference, but every little bit helps.
Old Mar 15, 2010 | 09:04 AM
46yblock's Avatar
46yblock
The 4100 series carbs basically came in two versions. 1.12 venturis at 600 cfm, and 1.08 venturi @ 480 cfm. The venturi size is cast into the carb body on its side. Also called a shoebox. The smaller version was used on 289 Mustangs. They keep rising in popularity, so a good used unit plus rebuild may end up costing as much as a new Holley 390.
Ford produced one version of the 1.12 venturi 4100 for the high performance K code Mustang, only. It wasnt used in any other model as I understand it. Havent heard of anyone trying one in a Y powered vehicle, but they are hard to find, easy to misidentify, and even more expensive.
4100s like their little brother the 2100s are great carbs. But on an "A" intake with adapter the 390 Holley sounds like the way to go.
Old Mar 15, 2010 | 10:56 AM
charliemccraney's Avatar
charliemccraney
The largest CFM I could see on any Y block ever is 600. That sitting on a race engine.
On race Y's, 650cfm and higher is not uncommon. The Y in the engine masters ran a 950. In testing, a 1050 dominator showed an improvement but there was not enough time to build an adapter which fit the rules. So they can run much larger carb in certain circumstances. Like any engine, it depends a lot on how it is built and where it will operate.
Old Mar 15, 2010 | 02:13 PM
flipklos's Avatar
flipklos
I am realizing they probobly used a stroker kit here but a 292 with perfect brathing capabilites would have to turn over 12,000 rpm to use a 1100 CFM dominator.
Large carbs are generaly a waste of money on street driven engines. The ammount of power gained by the larger carb is lost as it is sitting at the high end of the rpms. Would you drive around town in second gear at 5500 rpm to make power?
Old Mar 15, 2010 | 03:28 PM
charliemccraney
It is a stroker - a 4" stroke, for 375ci. It would make a very nice street engine. It would definitely be a performance engine but it has decent street manners and ran on 91 octane. It put out 386ft/bs @3000rpm, peaking at 415.9ft/lbs @4700rpm. The testing range was 3000rpm to 7000rpm. It idled at 900rpm. The Dominator put out even better torque. This goes to show that the build of the engine has a lot to do with the ideal carb size.
But, you are right, the engine used by unibody62 is mostly stock and by no means will a large carb be desirable, thus the reason we suggest something in the 400 to 500cfm area.
Old Mar 16, 2010 | 12:40 AM
flipklos's Avatar
flipklos
Ive been telling 302 owners for years that a 390 or 450 CFM carb would give great milage, throttle response and power. No one can listen though.
Yes, I do realize that a highly modified engine turning high rpms can use 1000CFM. I belive that certain power packed 289 fords had in excess of 800 CFM from the factory.
Even though; most hot engines, of less then 350 CID do not need in excess of 600 CFM.
Old Mar 16, 2010 | 12:55 AM
46yblock's Avatar
46yblock
The power packed 289s were the K code Mustangs with a special 1.12 venturi 600 cfm 4100 carburetor. High revving with tall HP numbers, though dont know the figure.
Dont want to dwell on this much more, but if a person thinks there is wiggle room for a 600 cfm Holley or Edelbrock on a close to stock 292 (I dont), there is none with a 600 cfm 4100, meant for the larger displacement FEs. Holleys are tuneable, 4100s were produced in many configurations each meant for a particular weight of car/truck, transmission, displacement, rear end, color...
Old Mar 16, 2010 | 02:08 AM
flipklos's Avatar
flipklos
I will get off the issue, and back on track.
The autolite 4100 will not fit on the "A" type manifold. That carb uses the same bolt pattern as the holleys.
You need a "B" manifold Then I would use a 390 or 450 CFM holley or a tuned down 500 CFM edelbrock. The advantage to the holleys is that they are cheep and easy to tune to the application. The drawback is that they have a tendency to leak.
Old Mar 16, 2010 | 02:27 AM
46yblock's Avatar
46yblock
Autolite 4100, Holley 390-465-600, Edelbrock 500-600, all take the same adaptor, as they all have the same bolt pattern, and with the adaptor will fit the A type intake. The question has been which is the best choice in this situation.
If it were me I would go with the earlier post that said forget it all and get a B, sell the A.
muscletruck7379
Dec 28, 2011 06:02 PM
rswhitmore
Flathead V8 & Flathead 6
Oct 18, 2007 09:45 PM
Knight70F250
Dec 12, 2006 06:46 PM
sbishop
19
Jan 15, 2004 08:30 PM
btorear
Nov 5, 2003 12:39 PM
