OK guys... Educate me...
this one has the correct 9" rear end included!
The 57-60 trucks, are another body style, popularly referred to as "refrigerators" around here for their somewhat boxy shape.
Here's a website with tons of pics;
Car Pics Index by Make - 125,000+ Car Pics
You can look up Ford trucks for many different years and get a feel for what you like and don't like
Bobby
Basically, 48 - 50 are almost identical, 51/52 are the same (small changes to trim and 52 had ohv 6)53-55 are the same (except 53 had a flathead V8) 56 is very similar to 53-55 but has the straingt windshield a post.
Here's the link otthe photo gallery:
1951 Ford 1, 1951 Ford F2, 1951 Ford F3 Pictures
If you see a body style you like come back and ask us about the stock drive train and possible conversions!
As far as drivetrain... I'm looking at a blown 460 dumping somewhere between 450/550 HP. I think that'll make it fast enough I'll enjoy driving it. But, not too fast I can't drive it on a daily basis. I can even achieve this with much smaller displacement. But, there's no bragging rights to saying... "I got a 302 or 5.0 in this". When people hear "It's a blown 460..." they'll cream their pants.
As far as tranny... still up in the air with it. I'd love to go old school gear banger 4 speed. But, a Tremec T6 would also be nice. Then... there's the whole.. I'd want to cruise it and let the throaty 460 rumble up and down ol route 66 at night. So, an auto w/ OD would also be nice.
The one part I'm not 100% sure on is the suspension modifications and conversions. I know I'll run a 9" with PDB. But, what front end should I use to hold the weight and provide stability and comfort? I want this truck to be a chin dragger (2" off pavement). I want it to feel stable around corners at reasonable speed so, very little body roll. But, have enough suspension to make it comfortable at highway speeds of 85-95 mph.
With that said and done... Headers/seats/wiring (imagine centec or painless makes a harness for this?) etc. Little things will need to be discussed. And places to purchase said parts like LMC or the like?
Guys... I'm not new to building things. So, don't be shy to give me any heads up on things. Just think this is the next builder I'm going for after I'm done with my 72 Bronco I'm building now. (5.8L/ZF/Atlas/HPD60/Sterling10.25)
The wiring harness has two wires for the push button. The ignition switch has a fourth center post. After connecting and rechecking all wiring, I turned the key and nothing. Motor wouldn't turn over. Eventually, I ran a wire from this center post to the little post on the solenoid and the motor will now turn over, but alas no spark from the coil. I can push the button or turn the motor over with the key, but no spark, which resulted in me putting on a new 6 volt coil just in case. I have no idea why there is no spark from the coil--------HELP
