rear spring airbags
Old Mar 12, 2010 | 10:44 AM
jleal_21's Avatar
jleal_21
rear spring airbags
i have a friend with an 05 superduty that has some airbags on the rear spings, since he doesn't tow anything heavy they are useless to him and is willing to sell them to me for about 150.00. my question is will they be easy to modify into my 96 f250? is it worth it? if not what would be a reasonable price for them considering they would need to be fitted into my truck.
Old Mar 12, 2010 | 03:24 PM
79_250RangerLariat's Avatar
79_250RangerLariat
I'm running firestone air bags made for an 05. IIRC I had to modify the one bracket, cut/weld shorter I belive...... but they work great. Mount on the inside of the spring under the frame. Only problem is over 15-20 lbs empty will jar you out of the truck, with a load smooth as silk
Old Mar 12, 2010 | 03:36 PM
jleal_21's Avatar
jleal_21
is 150 a good deal for them?
Old Mar 12, 2010 | 03:39 PM
foxracing0934's Avatar
foxracing0934
IIRC they are like $400 and change new so as long as they come with everything that he installed them with then yes that is a good deal. And you also want to make sure that the bags are not ripped and that they still hold air.
Old Mar 12, 2010 | 11:47 PM
oldbird1965's Avatar
oldbird1965
I love mine! With the big *** 5er I bought I thought I would have to buy a 1 ton dually and start all over again with the mods. Firestone cancelled that idea!
Old Mar 13, 2010 | 09:52 AM
offrdmania's Avatar
offrdmania
Very minor modifications to get them to work, you are good to go. $140 is cheap if they dont leak. Just be sure to always leave atleast 5lbs in the bags at all times so they dont collapse, thats when they rip.
Old Apr 16, 2010 | 08:56 PM
jleal_21's Avatar
jleal_21
79_f250 rangerlariet do you think that you could post some pics of the way you put them in? i installed mine and the seam to rub just a hair on the tires. i didnt modify anything so maybe thats why. i run 285/75/16 on stock rims, could this be that they are rubbing? i drove the truck about 30 miles since i put them on and they just seam to rub when the suspension compresses some cause they haven't gotten damaged. please help if you can. thanks
Old Apr 16, 2010 | 09:44 PM
fordpride's Avatar
fordpride
the wider tire is most likely the reason they are rubbing.
Old Apr 17, 2010 | 06:57 AM
79_250RangerLariat
I posted some pics in my gallery (forgot how to post in a post). Where are your bags centered? Mine are almost directly under the frame. Definately don't want any rubbing
Kpt3
6.7L Power Stroke Diesel
Oct 18, 2014 08:58 PM
90pioneer
Aug 8, 2014 12:25 PM
Rudder79
Aug 20, 2013 04:02 PM
Helidriver
Aug 27, 2010 03:00 PM
Ford Truck Racer
Apr 16, 2007 07:43 AM
