Sponsored by: Real Truck
High rev at idle
Old Mar 12, 2010 | 09:40 AM
docsuby's Avatar
docsuby
High rev at idle
Hey everyone, sen a lot of posts that mention it, but nothing that indicates a fix. I have a 00' f250 with a 6.8 v10, 100k miles on it. Yesterday I went out to start the truck (around 32 degrees, REALLY foggy) and it hesitated while starting. After I finally got it started, it won't rev below 2k rpm. If I step on the gas it goes up to 3k rpm and slowly comes back to 2k rpm. Even after it's warmed up it stays at 2k rpm. Even pulls against the brakes (though the transmission pulls it down to around 1100-1200 rpm at stop lights.) Had a guy tell me it's a vacuum leak, but I can't find anything leaking and the hvac works fine (move fast between zones, doesn't shift zones under load, etc) another guy says the iac may be dirty, any suggestions?
Old Mar 12, 2010 | 09:57 AM
Fishin76's Avatar
Fishin76
Vacuum leak would do that. Check the PCV valve and it's hoses and connections to the manifold. That is usually a larger hose, and can affect the idle that way.
Old Mar 12, 2010 | 10:29 AM
dkf's Avatar
dkf
Did you try what was mentioned in this thread?
https://www.ford-trucks.com/forums/9...revs-high.html
tarheel007
15
Mar 11, 2013 08:23 PM
livinlots26
Mar 3, 2013 07:40 AM
SHOpar
Jun 17, 2010 09:31 AM
docsuby
Modular V10 (6.8l)
Mar 12, 2010 11:42 AM
Fordcr
Modular V8 (4.6L, 5.4L)
Jul 20, 2003 01:41 AM
