Dumb problem, replacing fuel filter.
Old Sep 23, 2012 | 01:00 PM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Thumbs down Dumb problem, replacing fuel filter.
i have never had trouble with a ford style fuel filter before, but after removing the plastic clips the hoses will not simply slide off the filter like all the others have. The filter is old looking, not rusty but old. Is there something in the fittings that can seize??? I even used a screwdriver to pry up on the fitting from the filter.
Like I said, dumb problem to have. I just don't want to have to replace the fuel lines by prying too hard.
Old Sep 23, 2012 | 01:12 PM
GoinBoarding's Avatar
GoinBoarding
Are you using a fuel line disconnect tool? The little metal or plastic deal that slides into the fuel line coupler. I have this set, always worked: Great deal on Lisle 37000 at ToolTopia.com
Old Sep 23, 2012 | 02:24 PM
danr1's Avatar
danr1
Depends on what "year" talking about here. I'm not seeing where any vehicle information was given?
Old Sep 23, 2012 | 02:32 PM
bashby's Avatar
bashby
If it has the plastic, U shaped clips it should just pull apart, no tool required. Maybe spray some penetrating oil in there and try to turn the filter.
Old Sep 23, 2012 | 02:39 PM
Bad Bad Leroy Brown
Smile
My bad on the info, will the option for a sig just show up one day in my control panel??
97f250 HD 4x4 with duel tanks. It looks like they both go through the same filter on the drivers side frame. No, I have not tried a line disconnect tool, didn't think it used one! Like I said, this style
has just slid off for me before, but that was a car.
I'll give it a shot, thanks!!
Old Sep 23, 2012 | 03:10 PM
White 97 xlt's Avatar
White 97 xlt
It should be there now, it is supposed to be active after 25 posts....
Old Sep 23, 2012 | 03:17 PM
bremen242's Avatar
bremen242
Shoot some PB blaster or something in the spring-side of the fitting.
Make sure that you can turn the fitting on the filter.
Worst case is that you might have to 'free' the spring inside the fitting with a small screwdriver.
Once you have that done, the fitting tool should work.
Old Sep 24, 2012 | 09:32 AM
Bad Bad Leroy Brown
Last time I messed with it ,the filter would spin. I'll try to change it out tonight with the tool.
Thanks!
Old Sep 24, 2012 | 11:02 AM
96f15013ddie's Avatar
96f15013ddie
I've had trouble with those I got this fuel/ac line removal tool that looks like double sided scissors with C's on each side making it fit alot of different line sizes. PB blaster, tapped with a hammer and it slid right out (using the tool)
Old Sep 28, 2012 | 01:45 PM
Bad Bad Leroy Brown
Hot-dam! It worked!
I had a cheap set of plastic disconnect tools and the small grey one worked perfectly after a bit of persuasion. Might invest in a metal set since these fittings appear to be all over the fuel system. I was mistaken about the plastic clips, they came with the new filter but were not used.
Thanks again!
MichaelKnight
1983 - 2012 Ranger & B-Series
Aug 17, 2017 07:24 AM
VONxRUBENxLA
Aug 1, 2011 02:58 PM
fordtruck88
Jul 4, 2007 10:24 PM
Alta
Mar 26, 2006 06:34 AM
fshoffner
13
Jan 27, 2000 12:59 PM
