Coolant Flush
Old Mar 11, 2010 | 11:56 AM
MJMETHOW's Avatar
MJMETHOW
Coolant Flush
A while back saw a good post on flushing the 6 liter coolant and now I can not find it.I have 72 k.Been changing oil every 5 k and fuel every 10 k.Going to do the coolant bypass at the same time.Also in the next year going for a egr upgrade and oil cooler up grade.I just want to be proactive on this motor.
Thanks
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"><input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Mar 11, 2010 | 12:46 PM
texans's Avatar
texans
Here is the post on coolant flush. https://www.ford-trucks.com/forums/9...nge-101-a.html
Old Mar 11, 2010 | 12:52 PM
69cj's Avatar
69cj
1. Drain coolant
2. Add 2 cans of VC-9 and top off with distilled water.
3. Drive 20 to 30 miles, preferably at highway speeds.
4. Drain radiator at petcock first, then pull lower hose. Then remove block plug on driver side. Not necesary to do passenger side.
5. Remove t-stat. To do this, remove air cleaner. Then 2 nuts on t-stat housing. Pry press. sensor bracket off of studs. Tight fit but it will move. Remove 2 more nuts and pull t-stat and housing from studs.
6. Remove t-stat and put housing back on. Re-assemble everything and fill with distilled water.
7. Run at 1200 rpm's for 3 to 5 minutes and drain as described in step 4.
8. Repeat 4 to 5 times or untill water coming at is as clear as water going in.
9. Install t-stat using new O ring. I used vaseline to hold the O ring in place.
10. After everything is re-assembled fill with a 50/50 mix of Ford premium gold or Zerex GO-5.
11. Start engine and check for leaks. This is a lot easier and quicker than it sounds. If you don't remove t-stat then you have to run truck between each flush till t-stat fully opens and then let cool down to work on it.
Highly recommend installing coolant filter kit while cooling syatem is empty. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Old Mar 11, 2010 | 02:05 PM
Cowboy65's Avatar
Cowboy65
MJMETHOW, welcome to FTE.
If you haven't already check out the Tech Folder. You'll find lots of good info for keeping your truck in top shape.
cwordsmith
18
Apr 3, 2016 09:20 PM
Circle5
Apr 12, 2010 09:14 PM
Offroadracer426
Mar 9, 2010 07:45 AM
cwordsmith
Feb 3, 2010 01:37 PM
eldorado
2009 - 2014 F150
Aug 17, 2009 11:25 AM
