Boost levels while towing????
Old Mar 11, 2010 | 07:39 AM
Moto52's Avatar
Moto52
I was wondering that some of the boost levels you guys see going down the highway and relatively flat ground? I purchased a 8.5x20 ft V-nose car hauler trailer and i'm running higher boost then I thought i would be. at 60mph I am running around 6 to 7lbs of boost. and if I go 70 to 75mph i'm at about 10lbs. I use to have a 28ft travel trailer and i didn't remember running this much boost.
Old Mar 11, 2010 | 07:45 AM
riverrat41's Avatar
riverrat41
That sounds about right.I see many different boost readings during different road conditions(hills).Running flatland at 70 I get about 5-7.It is very responsive when passing or hilly areas.
Old Mar 11, 2010 | 07:48 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I am pretty close to those numbers. If I start climbing a hill, I will get over 20# boost.
Old Mar 11, 2010 | 07:50 AM
big poppa's Avatar
big poppa
Another X3, sounds like my numbers too...
Old Mar 11, 2010 | 07:55 AM
Robert6401's Avatar
Robert6401
Sounds about right for me, too. I cruise on flat land at about 7-8psi. Was seeing about 18-20 on hills last week until I developed a boost leak I now need to track down.
Old Mar 11, 2010 | 08:37 AM
whitesdford's Avatar
whitesdford
Sounds about right to me too. Pulling a 10k empty trailer, i see anywhere from 5-10 going down the highway, hills can get over 20 depending.....
Old Mar 11, 2010 | 08:44 AM
Kwikkordead's Avatar
Kwikkordead
Is your truck configured the same as when you had the first trailer?
That will make a big difference.
For instance, do you now have bellowed up pipes and you did not before?
Old Mar 11, 2010 | 09:07 AM
UNTAMND's Avatar
UNTAMND
i get 20-26psi while towing in 80e, and 20-24+ regularly in 60t
Old Mar 11, 2010 | 09:10 AM
redfire42's Avatar
redfire42
Sounds good to me to. Head winds would also play a part on how much boost you need to keep it a speed.
Old Mar 11, 2010 | 05:35 PM
Moto52's Avatar
Moto52
do you mean you peak at that or you stay at those numbers the entire time going down the highway??? what are you towing??
Old Mar 11, 2010 | 05:37 PM
Moto52's Avatar
Moto52
Yea when I had the travel trailer I just had my stock rims and 295/75/16 tires now I got 35/12.5 ..
Old Mar 11, 2010 | 05:59 PM
UNTAMND's Avatar
UNTAMND
I peak at those numbers. Whwn i tow my empty trailer I run 80e, I recently towed a 77 ford 150 miles in 80e and it loved it. Hauled a manlift 80 miles on 60t and it went great as well. Driving unloaded at that psi is crazy excessive. I cruise at 75-80mph around 8-10psi.
I tow everything from 6k-12k. I usually put 20-28k on my trucks between daily driving in the city, towing various things, and driving 300miles non stop empty/loaded.
