Sponsored by: Auxito
fluid from tail pipe
Old Mar 10, 2010 | 11:36 PM
panhead81's Avatar
panhead81
just changed plugs on 2000 f-150 5.4l after it was running rough, had codes for missfires on 2&8 checked cop's and injectors. Replaced plugs and truck is running good but now i have fluid comming from tail pipe.
Old Mar 11, 2010 | 03:42 AM
phil6608's Avatar
phil6608
Describe the fluid and how much?
It sounds like condensation in the exhaust system.
Old Mar 11, 2010 | 07:03 AM
Duheme's Avatar
Duheme
I agree- need to know a bit more. It is common for condensation to drip and sometimes run out of tail pipe, it occours as part of the funtion of the cat. converter. Do you get the fluid after the truck is fully warmed up? Does it feel greasy? Does it have an oder to it?
Old Mar 11, 2010 | 07:13 PM
projectSHO89's Avatar
projectSHO89
Water is a normal by-product of combustion.
Old Mar 11, 2010 | 09:09 PM
steve(ill)'s Avatar
steve(ill)
monitor the radiator overflow tank and see if the level changes. if not.. no problem.
Old Mar 13, 2010 | 04:35 AM
whitefordexplorer's Avatar
whitefordexplorer
whatever you do, dont drink it! if its alot of fluid, you may have a coolant leak. if its not, then its just normal condenstion.
