Help needed with transmission ID
Old Mar 10, 2010 | 09:45 PM
Robert Magee's Avatar
Robert Magee
I have a 1976 f350 supercab that I recently purchased it has a 390 according to the tag on the door it gives an A for the transmission. It is my understanding that this means that it is a 4 speed manual New Process 435. I took off the floor plate and it dont appear to be a New Process trans. I believe the New Process is a cast iron body top loading with an aluminum cover this is all cast iron. The tag I found located on the top cover right rear bolt reads D3T3-EBI or EB1 I cannot locate any info on these numbers? This trans needs a new speedometer drive gear. It is a 7 tooth gear with a left hand twist which I cannot locate either. What transmission is this?? Is this the right type of twist for this gear? I have found one with the opposite twist that fits an older mustang.
Old Mar 10, 2010 | 09:49 PM
montana_highboy's Avatar
montana_highboy
Sounds like someone swapped out the NP435 for a T-18.
Old Mar 10, 2010 | 09:51 PM
85e150's Avatar
85e150
Pics and numbers to check here. If first is non-synchro and really low, and it's all iron as you say, it is probably a T18.
First synchro, T19.
Domestic Truck Tranny Guide
Old Mar 10, 2010 | 09:53 PM
Robert Magee
yes it has a granny just like the 435 geared so low you could pull a house off the foundation lol
Old Mar 10, 2010 | 10:03 PM
Robert Magee
just had a look at the link for the Domestic Truck Tranny Guide and it looks like ur right T-18. I am kind of wondering now if this is a 390 or a 360 its a 2bbl and not a four like it says but it does look like a 390. Thanks
Old Mar 10, 2010 | 11:50 PM
montana_highboy
There's just simply no way to discern a 360 from a 390 externally, you'll need to measure the stroke...
3.50"=360
3.78"=390
tlambert
Oct 13, 2013 10:39 AM
HydroDog
Jul 9, 2013 10:11 AM
hoxiii
Oct 17, 2007 06:13 PM
buick64
Missouri Chapter
Aug 6, 2007 11:23 AM
klondike
Jul 31, 2001 06:42 AM
