tail light electrical problem help
Old Mar 10, 2010 | 09:25 PM
bubbasinafordf150's Avatar
bubbasinafordf150
i went over to my grandparents and got my grandpas truck to do some work on it for him and heres what makes no sense, ive got running lights on the rear, the left turn signal works but the right one doesnt, and no brake lights also when i turn the running lights on the right turn signal indicator on the dash comes on, also did ford ever come out with a factory brake box for a trailer and if so what did it look like truck is mostly orignal from what i can tell, its 76 with a 77 grill 351m or 400 not sure, f150 xlt with almost ever option for that year, the wiring has been hacked on at some point in its life, as there is black tape wraped around almost every wire concievable, and how did the BOO (brake on an off) switch wire up to the rear tail lights, thanks in advance
Old Mar 10, 2010 | 09:39 PM
montana_highboy's Avatar
montana_highboy
Check the easy stuff first i.e. bulbs, sockets, grounds, etc. if they all check out ok i'd look into the TSS.
Old Mar 10, 2010 | 10:17 PM
bubbasinafordf150
so the brake lights are also incorperated in the tss to. if thats the case then thats on my uncle as hes the one who put the turn signal switch in
Old Mar 11, 2010 | 12:01 AM
montana_highboy
That's correct, when the TSS goes bad it can cause problems with the tail lights that mimic a bad ground or a short, just all around weirdness.
Old Mar 11, 2010 | 03:41 AM
madrockwyo's Avatar
madrockwyo
Also a corroded socket or bad ground can allow the tail light to feed back to turn signals or visa versa.
Old Mar 11, 2010 | 11:00 AM
bubbasinafordf150
ok, well looks like hes going to be the one to do that as i was just supposed to fix the steering and radius arm bushings,
DGMFORD
Sep 22, 2013 09:07 PM
SocialDistortionFan
May 14, 2013 08:18 PM
barefootstu
Electrical Systems/Wiring
18
Jan 28, 2007 12:42 PM
OldBlue66
May 25, 2006 06:28 PM
kc0mdk
Dec 9, 2004 08:58 PM
