Radiator problems.
Old Mar 10, 2010 | 08:29 PM
woodn1's Avatar
woodn1
Radiator problems.
I have a 351 w/ with a c-6 tranny, that has a problem with the transmission cooler , inside the radiator. My trans. fluid has gotten "milky" and I have been told the line inside the radiator must have a pin hole in it.
Can this radiator be fixed or is there another remedy, such as an auxilery cooler that will sufficiently cool the fluid? The radiator is a thick one and probably expensive. Any help is appreciated.
Old Mar 10, 2010 | 09:21 PM
Franklin2's Avatar
Franklin2
I have heard of people running just a aux cooler, but in the winter the radiator helps the tranny fluid warm up quicker, and the instructions with the aux coolers always tell you to keep the radiator cooler with the aux cooler.
One more problem you may have. If you take the tranny lines off the radiator, you may have to plug them somehow or you might have a coolant leak if your cooler has a pinhole.
Old Mar 11, 2010 | 07:51 AM
woodn1's Avatar
woodn1
It sounds like the best thing to do, is buy a new radiator. Plugging the tranny lines at the radiator would not be a problem, but I never thought about the coolant warming the trans. fluid when it is cold. Thanks for the quick reply.
jccapri
13
Dec 30, 2012 05:52 AM
johaner78
15
Jul 31, 2012 06:37 PM
Boba Fett
May 30, 2011 10:36 AM
linckeil
Sep 12, 2009 11:02 PM
cbremer
Apr 10, 2000 09:40 PM
