spare tire help
Old Mar 10, 2010 | 06:57 PM
MonsterTruck\m/'s Avatar
MonsterTruck\m/
spare tire help
i feel stupid for asking this question but i spent 30 mins on my back trying to remove my spare tire but with no luck... help
i have a 76 f-100 with an aft axle gas tank with the spare mounted right below that
thanks
Old Mar 10, 2010 | 07:34 PM
Mexican77's Avatar
Mexican77
That's why I removed my spare from down there cuz I't was very hard to mount/dismount it, but if I remember well, there was only one nut to remove, just be careful cuz those tires are pretty heavy, I'm trying yo find some pics if I found some in the Haynes manual, I'll post it for you.
Old Mar 10, 2010 | 07:39 PM
MonsterTruck\m/
thanks bro .. and yeah i got two jack stands to catch the tire since i would like to keep my ribs in one piece
Old Mar 10, 2010 | 08:09 PM
jade79's Avatar
jade79
There should be a bolt on the right (passenger) side holding the tire cradle to the frame with a loop in the end. Place the skinny end of your lug wrench in the loop and loosen the bolt. Once you have it loosened a fair amount, the tire should be able to swing enough to allow the loop to pass through the larger diameter hole in the tire cradle and tilt to the ground. You may need to spray some penetrating oil on the threads above the frame 1st and allow some time for it to work.
I tossed my spare tire in the bed since I have a cover. With my luck I can see myself getting a flat in the rain while I'm wearing my good clothes and have to lay on the wet ground and wrestle with that.
Old Mar 10, 2010 | 08:30 PM
starmilt's Avatar
starmilt
The first and second time I had a flat there was about a foot of snow on the cround in colorado. The second time I stayed under there and removed the rack, it is probably still on the side of that dirt road some 33 years later. lol After you screw the bolt out some you have to lift the tire and rack up to move the bolt over to the bigger hole it slips threw. Make sure the loop on the end of the bolt is turned the right way before you lift it or you will fight it for a second then have to let it down and turn the bolt .
Old Mar 10, 2010 | 08:47 PM
MonsterTruck\m/
yeah im was doing that with my lug wrench but the nut at the top was moving... i tried to hold it but its so hard to get up there
Old Mar 11, 2010 | 03:47 PM
n3vyk's Avatar
n3vyk
I have a 76 F150 Styleside. On my truck the release is on the passenger side. There is a small "L" shaped pin that you pull out, kinda like a lock. Then squeeze the handle. The latch moves in, and the spare tire rack can be lowered. No bolt to be loosened on mine. Lowered it last weekend to R&R the fuel tank.
Old Mar 12, 2010 | 02:00 PM
Mexican77's Avatar
Mexican77
https://www.ford-trucks.com/forums/a...2&d=1268365397
Old Mar 13, 2010 | 04:39 AM
DailyDriver's Avatar
DailyDriver
If you have a floor jack, place the jack under the spare and use the jack to lower it. Put it back up the same way. A sissor jack can also work. Good luck.
RAPR
6.7L Power Stroke Diesel
Sep 12, 2012 02:51 PM
54Guy
Mar 21, 2011 10:12 PM
UaVaj
Apr 2, 2009 09:08 AM
braddok
1983 - 2012 Ranger & B-Series
Jan 17, 2008 07:57 PM
youdog99
Oct 16, 2002 09:07 AM
