Sponsored by: Auxito
Cheap intake mod...
Old Mar 10, 2010 | 08:29 AM
stvMo1's Avatar
stvMo1
Cheap intake mod...
I just can afford $300.oo or more right now for my 2004 screw 5.4 so I did my own..
Bought 3in tubing for $15.00 from http://usedturbos.net/Catalog/index....d=17&Itemid=53
3x4 plbg boot from Lowes $ 7.50
3in Spectra cplg from Autozone $8.00
I JB welded 1/2 copper tubing for the vaccum lines and drilled a hole in the plg boot for the air temp sensor .
I did the Got mod at the fender .
It seems to have better throttle response and a bit more power. Do'nt know about mileage yet.
I'm gonna get a K&N filter one of these days to let it breath a little easier.
Old Mar 10, 2010 | 09:35 AM
Hybris's Avatar
Hybris
Looks very neat and well done.
Old Mar 10, 2010 | 09:54 AM
fordf150farmer's Avatar
fordf150farmer
that is pretty slick right there. it is just to bad that you still have that big ol hole in your cover plastic that says 5.4 on it. if it were mine i would want to finsd a way to make that gap smaller. but thats just me. i wonder is that pipe you used better performance wise than just removing the stock intake silencer? either way very nice
Old Mar 10, 2010 | 04:52 PM
stvMo1's Avatar
stvMo1
Thnx guys..
Yea,I'm figuren out sometn to close that big hole in. By just taken the silencer out seems to me there would be allot of turbulence . This should be a little more direct in gettn that air in there...
Plus I can always go back stock.
Old Mar 10, 2010 | 06:50 PM
93 mix 'n match's Avatar
93 mix 'n match
put a chrome plate around it. it'll be badass.
Old Mar 11, 2010 | 09:05 AM
stvMo1's Avatar
stvMo1
Good idea, I'm gonna dig around the oldladys fancy silver serving plates while she's at work
Old Mar 11, 2010 | 02:26 PM
stvMo1's Avatar
stvMo1
I cut up the top of an old after market air cleaner and stuck it in there...
I think it came out decent...
Old Mar 11, 2010 | 04:18 PM
93 mix 'n match
dude thats awesome. i think im gonna make something like that...beats the hell out of a $300 kit thing.
Old Mar 11, 2010 | 05:54 PM
fordf150farmer
very nice. i like that. im gonna do the gotts and silencer delete, but once i come acrosse the materials i think im gonna try something like this.
Old Mar 11, 2010 | 06:21 PM
phil6608's Avatar
phil6608
That's as good if not better then any aftermarket intake!
Nice job.
Old Mar 11, 2010 | 06:23 PM
Hybris's Avatar
Hybris
I think we can dub this "The Stvmo Mod"
Old Mar 12, 2010 | 07:20 AM
stvMo1's Avatar
stvMo1
Thanks guys,I appreciate the compliments..
I've been outa work for over a year and try to find cheaper ways of doen everything.
I worked 34 years at the same place and got the shaft..
Old Mar 12, 2010 | 10:13 PM
Trucky911's Avatar
Trucky911
"I did the Got mod at the fender"
I did a search and can't find any thing. Could some one please help...What is the got mod? TIA...
Trucky911
Old Mar 12, 2010 | 10:21 PM
93 mix 'n match
basically enlarging the hole at the end of the airbox that goes into the fender.
Old Mar 12, 2010 | 11:36 PM
fordf150farmer
i havent done the gotts mod yet, but i hope to this week. basically you take about a 5 inch section of pvc, and shape one end so that it will fit into thw hole in the fender. make sure it can go all the way in. there are two peices of metal it has to fit through. then you take a 3" to 3" black rubber connector, and atatch one side to the pvc and one side to your filter box and tada! if its done right you shoud have to look really hard to see the pvc
