That's it...
I used 3" SCH 40 pipe and there is allot of sanding to get it to fit. I used a 4 1/2 hand grinder and a 4" belt sander.
If ya can find some 3" SDR 35 or 21 would make it allot easier. It's half the thickness of the SCH 40.
I used the 75. It's a little outa square but it is long enough where as the 90 is'nt.
I you use the 90 ,you'll have to add a section at one end or the other.
Mine was glued on and I woulda tore it up trying to get it off plus it's pretty thin rubber where it attaches to the plastic.
Plus I did'nt wanna tare up any stock parts. I can always put um back on to stock...
