92 7.3 KNOCK??
Old Mar 9, 2010 | 08:59 PM
CWOODNHD92's Avatar
CWOODNHD92
92 7.3 KNOCK??
Hey guys new to the site, Ive got a 92 f250 4x4 with a 7.3
non turbo with a e40d trans, and 220k on the odometer. Problem is Ive been chasen my tail around pinpointing a knock.
Sounds very loud from under engine near bell housing and will go
away when cracking the #8 injector. Ive already tried a rebuild injector
on #8 from oregon diesel, but knock just got louder.
Thinking it sounds like a rod bearing, but havent read any issues
with these motors, any input would be great, thanx
Old Mar 9, 2010 | 09:45 PM
starmilt's Avatar
starmilt
This doesn't sound good, It could be a rod or even a bad piston, but a knock is hard to diagnose over the computer. But if it clears up when you kill that hole there is a problem with it.
Old Mar 10, 2010 | 02:35 AM
hairyboxnoogle's Avatar
hairyboxnoogle
If you kill the cylinder and it goes away, its a rod bearing. If you kill the cyl. and it stays its a main or wrist pin. Wrist pin is a high pitched kinda rattle, vs the obvious and deppressing sound of a rod/main knock.
Old Mar 10, 2010 | 04:12 AM
rupejosh's Avatar
rupejosh
CWOODNHD92 welcome to FTE and the idi forum!!!!
if it goes away when you crack the #8 line its the #8 injector thats bad
Old Mar 10, 2010 | 04:17 AM
mistakenID's Avatar
mistakenID
Rupe, he already changed the injector and the knock got worse. I'd say rod bearing from the description.
Old Mar 10, 2010 | 04:54 AM
rupejosh's Avatar
rupejosh
ahhh crap im up way too late.lol
its just weird that it goes away when the injector is cracked because the rod is still moving right?
Old Mar 10, 2010 | 06:10 AM
WEST AUSSIE 94 250's Avatar
WEST AUSSIE 94 250
Rod still moving but no fuel means no big bang on top of it. Less downward pressure equals less noise. Sounds like rod bearing to me too, sorry.
Old Mar 10, 2010 | 07:50 AM
CWOODNHD92's Avatar
CWOODNHD92
Thanx for all the replies, sounds like I need to find a donor, I woulnt think that
its worth trying to rebuild with that kind of milage, or maybe ill just drive it till it
gernades....
Old Mar 11, 2010 | 08:26 AM
WEST AUSSIE 94 250
I have heard of older rebuilds.
Old Mar 11, 2010 | 12:23 PM
rupejosh's Avatar
rupejosh
if ya do a rebuild i doubt you will even have to mess with it ever again
Old Mar 11, 2010 | 09:11 PM
CWOODNHD92's Avatar
CWOODNHD92
been thinkin more about it today and was wondering if takin the pan off and
checking the crank journal/cylinder would be worth the time.
accept for the knock the engine runs stong, maybe, if nothings to bad, yankin the
crank out , havin it turned and slipping new bearings in wouldnt be too pricey.
its not like the truck is a show piece, any thoughts?.....
and how hard are the pans to get off, looks tight being a 4x4
Old Mar 11, 2010 | 10:15 PM
starmilt's Avatar
starmilt
They are tight but a member did it not toolong ago.
You have to raise the motor as high as you can and unbolt the pan and then take the pickup tube off, then hold your mouth just right.
It is possible it is a wrist pin too, a piston skirt knocks too but a little different than a rod,it's hard to explain.
Old Mar 11, 2010 | 11:34 PM
Marianna2003's Avatar
Marianna2003
Before I'd tear apart an engine to see if the rod bearing is shot, I would take the oil filter off and use a cold chisel to cut it open (carefully). Cut the paper element apart and look for metal filings. If there's a lot, something needs fixing.
PS:
A large pipe cutter will work or you could take it to a truck dealer. Many of them have filter cutters that you can use.
Old Mar 11, 2010 | 11:45 PM
CWOODNHD92's Avatar
CWOODNHD92
dont know if itll show much
just changed the oil about 200 miles ago,
, but could be worth a shot
Old Mar 12, 2010 | 12:14 AM
Marianna2003
If you've got the old filter cut it open. Probably threw it out. That'd be my luck.
