Dash buzzing
Old Mar 9, 2010 | 07:48 PM
katiesdad7's Avatar
katiesdad7
Dash buzzing
I have an 05 EB with the diesel and recently the dash has started to buzz sometimes. It seems to be coming from around the radio. I thought it may be a loose CD but I removed it and it still buzzes. It has to do with the load on the engine. I drive it like my grandmother and put very little load on it. I accelerate slowly. When I give it some gas the buzzing goes away.
I'm thinking something is loose under the black plastic dash part. Any ideas?
The Ex only has 30k on it.
Old Mar 10, 2010 | 07:59 AM
ReAX's Avatar
ReAX
put a phone book on the dash and move it around while you drive. If the noise lessens while its in one spot, it's near a loose panel.
Old Mar 10, 2010 | 08:19 PM
ke6zmy's Avatar
ke6zmy
I pulled off the trim panel, placed some 3m double sticky foam on the rubber bumpers.
Try the following thread;
https://www.ford-trucks.com/forums/9...ml#post8367659
There are small off white cushions, not pointed out in the pictures but they are there in the pictures.
Old Mar 11, 2010 | 06:18 AM
katiesdad7's Avatar
katiesdad7
Super, thats what I was looking for. But how do you remove the radio?
Old Mar 11, 2010 | 07:09 AM
87mh's Avatar
87mh
First, purchase a good "how to" manual, and then get a set of these:
Universal DIN Radio Removal Tool.
Crutchfield has them for about 5 bucks - try your local parts supplier.
Don't try just to bend a coat hanger - the angst is not worth it.
Also, there is usually a bolt hidden somewhere above or below the radio - thus the necessity of a good manual.
Old Mar 11, 2010 | 09:21 AM
ke6zmy's Avatar
ke6zmy
Yes, go to your local Kragen, O'Reilly, AutoZone, and buy the tools. I tried the hanger way and as 87mh said it is not worth the anger, frustration, and the possibility of damaging the keeper springs.
The tools come with use instructions.
Once the radio is out you remove the screws as shown in the pictures and pull the dash trim towards you. Then, unplug the various plugs and set the trim asside.
The plugs can not be mixed up. They only attach to each other as designed.
