parts looking
Old Mar 9, 2010 | 08:30 AM
gambling209's Avatar
gambling209
parts looking
i have a 2001 excursion. working on it the other day, i noticed the front bump stop and the sway bar end links are really rotten.accually one bump stop was missing and the other was on its way out. can you get these made in poly? if so any idea where to buy?
Old Mar 9, 2010 | 08:38 AM
firemaster's Avatar
firemaster
Check out parts guy Ed. www.partsguyed.com
Old Mar 9, 2010 | 08:43 AM
onelionhunter's Avatar
onelionhunter
Try this
Alot of folks have used these.
Energy Suspension Parts: 4WD Super Duty (1999 - 2004 Models), Ford F250 4WD SD 1999
Once you find the kit you want, I have found them for less on Amazon and ebay on occasion.
Old Mar 9, 2010 | 08:50 AM
gambling209
thanks i have bought from parts guy before. great to deal with, but want poly. the ford stuff didn't last long. thanks for the link for the poly. i'll look into those.
Old Mar 9, 2010 | 09:04 AM
Ponyboychris's Avatar
Ponyboychris
I just replaced my sway bar bushing with the energy suspensions kit. Night and day difference in the ride quality. Here's my thread I started: https://www.ford-trucks.com/forums/9...nks-today.html
Old Mar 12, 2010 | 08:41 AM
gambling209
kits
energy sup. just emailed me back and said that kit would not fit an excursion. i find it hard to believe that ford made a diff setup for the x and the 250 of the same year. i had already bought it. if it doesn't fit i'll post it here.
Old Mar 12, 2010 | 11:15 AM
itsjustdan26's Avatar
itsjustdan26
If energy suspention doesnt fit, Give Ed or Clay a call. Also you can pick up a set of Moogs im sure from your local parts store of your choice.
Old Mar 12, 2010 | 11:23 AM
ron's power stroke's Avatar
ron's power stroke
i think this is the kit you want...
Energy Suspension Parts: 4 Wheel Drive, Ford Excursion 4WD 2001
Old Mar 12, 2010 | 12:48 PM
clem1226's Avatar
clem1226
Originally Posted by gambling209
. the ford stuff didn't last long. . .
I understand you want poly, no problem with that....just trying to put things in perspective
where those the original bumpstops on you truck and what year is it?
Old Mar 15, 2010 | 05:58 AM
gambling209
bump stop
the only reason for the bump stops are one has rotted off and the other front is on its way out. the end links are $66 apiece. i was not very happy with the amount of time they lasted.
Old Mar 15, 2010 | 09:34 PM
clem1226's Avatar
clem1226
I have the energy suspension endlink bushings, the only complaint is when it's real wet out they start squeaking...as long as their dry they are fine....maybe I didn't grease them well enough when I instaleld them
Old Mar 18, 2010 | 06:22 AM
gambling209
it looks like everthing is a go for the kit to be used on my excursion. the only diff is the sway bar is larger on the excursion than the 250. so the swat bay bushing is a no go.
