7.3 injector problem still!!!!
</NOBR> gage mounted to it. on the rh side of the motor. we have a pulse for the injector but when its idleing and i pull the plug off one of the injectors there is no change in idle, how ever i went to the lh side and pulled one plug and it idle down and missed. (like its suppose to ).. i pulled one good injector out on the left side put in it in the rh side. and pulled the plug and it idled down .. I figured it just had bad injectors. soo i replaced them witn new ones. I plugs the good injector back on the lf side and got the truck idleing again and pulled the plug . and it didnt idle down. nor did any of the rh side bank ... these are new injectors. could the be shortning out?i have put a ohm meter on the injectors and it reads .002..is that good?
any help would be greatly appreciated. david
<!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
