powerstroke trivia
Old Mar 9, 2010 | 09:09 PM
  #31
MADVAN's Avatar
MADVAN
It should have set an idm code.
Bill
Old Mar 9, 2010 | 09:16 PM
  #32
strokin'_tatsch's Avatar
strokin'_tatsch
my truck seems to be starting to do this. runs fine up by my work when i leave, then once i get on the freeway running 75-80mph it runs fine all the way up until i have to stop at the end of the freeway it idles pretty dang rough until i have sat in stop and go traffic for a few minutes. also my oil temp gets up to around 210* sometimes 212* if i'm at 80mph long enough. seems like it runs good again around 200* of EOT. don't know, maybe i have a similar kind of problem or something...
Old Mar 9, 2010 | 09:23 PM
  #33
Krisx125's Avatar
Krisx125
i have to tap my brake pedal to get it to idle..and when i do it idles so rough..And if i donw hit the brake it holds the gears...forever. Like its a stick..
Old Mar 10, 2010 | 07:57 AM
  #34
DRRXR's Avatar
DRRXR
Good
First Hellifixer good find on the pin.
Kris
either you brake pedal switch is bad and locking out your tc or you have a pin issue at the tranny grounding it out (combo of both) . But I would say its you brake pedal switch. Change it out.
Old Mar 10, 2010 | 10:23 AM
  #35
helifixer's Avatar
helifixer
Bill
that would have made life too easy!
