JC Whitney?
Old Jan 22, 2003 | 03:52 PM
szepj1's Avatar
szepj1
Question JC Whitney?
I am wondering if anyone has purchased any intake and/or exhaust manifolds from JC Whitney? I tried to go to www.jegs.com with the link provided by a user (be damned if I can find that message again) but the board appears to be down.
Anyhow, for those who have purchased the above from JCWhitney; any comments, good or bad?
Old Jan 22, 2003 | 05:03 PM
Vampiro's Avatar
Vampiro
JC Whitney?
why not check the online store here first.
Old Jan 22, 2003 | 06:25 PM
szepj1's Avatar
szepj1
JC Whitney?
Thanks, but I just checked the "Store", found nothing for my 300cid Ford six-cylinder. Thanks, anyhow.
Old Jan 22, 2003 | 08:45 PM
Chas1234's Avatar
Chas1234
JC Whitney?
Try looking for Offenhauser or Pace setter I bought a intake and a set of hedders from them ...I would strongly advise against the headers ,rather use EFI exhaust manifolds....also use a 2300 serices 350 cfm Holley 2bbl as the 390 CFM holley 4bbl is a little much for the low reving 300 I 6 ....If I were to do it again thats what I would do...The headers make starter removal a PITA and they tend to rust in a matter of months (mine did)
I hope this helps , talk to "Ford Six" as he has all of my old 300 parts on his engine and is quite happy with the results
Jon
'75 F100 4X4 5.9
'89 F150 4X4 4.9
Old Jan 23, 2003 | 03:13 PM
szepj1's Avatar
szepj1
Regarding those EFI headers; Really?
Are those split, so that you can attach two exhaust pipes to?
The Ford dealer here says that they (the exhaust headers) are in two pieces but they bolt together, thus leaving just the one outlet pipe.
Is this true?
Old Jan 23, 2003 | 04:32 PM
stractor's Avatar
stractor
Talking JC Whitney?
The EFI exhaust manifolds are split. There is a front and a rear manifold, they are not connected to each other, and there are two outlets one from each. These combine before the cat or the cat has two inlets ( don't remember which ) and exit the cat as one pipe to the muffler. This is based on a 1990 F-150.
Stractor
PS I believe the pipes combine before the cat
Old Jan 23, 2003 | 04:47 PM
szepj1's Avatar
szepj1
JC Whitney?
Do I ever owe a heap of gratitude to the folks that have been providing prompt and informational replies!!
I contacted a local auto-wrecker (60 miles from here, so not far) and was told that the set of headers off of an EFI 4.9l will fit my 1984 4.9! Yeahh, that bit of information [from stractor & others] just saved me $400US plus shipping minus the $133.00 Cdn (no shipping).
Man, do I love this board!
By the way, thanks also for that URL re: performance numbers before and after (bigblocksix.com/dyno_runs/stock.png & _dp_500_252.png). Verrry helpful!!
Old Jan 23, 2003 | 06:12 PM
Chas1234's Avatar
Chas1234
JC Whitney?
IF I were you I would also get the front pipe also, (save you time and money for fabricating the exhaust)
Jon
'75 F100 4X4 5.9
'89 F150 4X4 4.9
Old Jan 24, 2003 | 05:25 PM
szepj1's Avatar
szepj1
JC Whitney?
OK, but I am confused, chas1234
What "front pipe" are you talking about? Are you referring to the plumbing underneith that already exists on an EFI?
Old Jan 24, 2003 | 05:40 PM
Ford_Six's Avatar
Ford_Six
JC Whitney?
The front pipe is what is used from the factory, going from the manifolds to the cat. The two pipes are 2" in diameter, and both go into the cat. Just cut immedietely in front of the cat, and run dual 2" pipes out. This is the system I have, and it works great. Or, you could keep the front cat, and run a 2.5" or 3" single. Either way, this is a great alternative to having custom pipes made, or running headers
JJ1955
1997 - 2003 F150
Mar 28, 2011 06:18 PM
secondarychaos
17
May 14, 2008 02:33 PM
BinaryWhisper
Apr 2, 2006 08:52 AM
300sixowner
Feb 3, 2004 05:30 AM
Colossus
Jul 20, 2003 08:27 PM
