Water Pump leaking
Old Mar 8, 2010 | 11:10 AM
MMSGuthrie110's Avatar
MMSGuthrie110
Water Pump leaking
96 F150 4.9l, I have a steady thin flow of coolant leaking from my truck. i found that it is coming from a hole (about 1/4" dia) on the side of the water pump. It is on the driver side. there is no plug of any sort in the hole and im wondering if there is supposed to be or if i could thread a bolt in there to plug it?? It has been doing this for a few days but hasn't been a steady flow untill today. i added some coolant a few days ago and temp is fine when i drove it. Help aAnybody???
Thanks, Dylan
Old Mar 8, 2010 | 11:18 AM
quicklook2's Avatar
quicklook2
you need a new water pump.
that is the weep hole and leaks after bearing fails.
Old Mar 8, 2010 | 11:22 AM
MMSGuthrie110
dam... looks like i got a project to do...
Old Mar 8, 2010 | 11:46 AM
Volvo92906's Avatar
Volvo92906
These waterpumps are easy. What. like 2 or 3 bolts and the belt and youre good to go.
And I agree with Quicklook, weep hole. seals in waterpump, need to replace it.
Old Mar 8, 2010 | 12:28 PM
andym's Avatar
andym
They're a little harder than that on the 4.9. You have to use the dreaded fan clutch tool.
Old Mar 8, 2010 | 01:13 PM
Volvo92906's Avatar
Volvo92906
Really? I didnt think so, but then again I dont have my truck right now so I cant go look at it. Either way, at least you dont have to pull the whole engine apart for it.
Old Mar 8, 2010 | 01:16 PM
andym's Avatar
andym
100% sure. That part of it is the worst. That nut can be stuck on there really tight.
Old Mar 8, 2010 | 01:17 PM
SaikotikGunman's Avatar
SaikotikGunman
DUN DUN DUN!
Old Mar 8, 2010 | 01:44 PM
quicklook2's Avatar
quicklook2
if radiator is in then put cardboard between it and pump.
remove fan clutch first, get tools and maybe a chain wrench to grip it.
comes of lefty loosey, no matter what the haynes manual says.
remove shroud second.
spray bolts for a day or so.
good time to put on new belt: use a goodyear gatorback belt, usually lifetime warranty.
E55 Bulldog
Apr 24, 2016 07:27 PM
r___r
May 27, 2013 12:20 AM
ve7kilohertz
Jul 14, 2012 03:39 PM
John SCB
Feb 22, 2010 04:08 AM
papadelogan
21
May 10, 2008 08:26 PM
