P0273 code
Old Mar 8, 2010 | 08:40 AM
Baciagaloop's Avatar
Baciagaloop
P0273 code
Hi all, I am getting a P0273 Code, Cylinder 5 injector circuit low, last week I had a cylinder 7 injector circuit low, but light went out by itself. Today, light went on and cylinder 5 Ijector Circuit low. Any one know what is causing it, and what I need to repair it?
Thank You, Bacci
Old Mar 8, 2010 | 09:24 AM
npccpartsman's Avatar
npccpartsman
P0273 means that you probably have a bad spool valve coil on one of the injectors. Not something that will fix itself. Since you had #7 previously and it "fixed itself" I would be looking for a wire chafe problem and not necessarily a failed injector since 5 and 7 are adjacent to each other. At least it's something you can do yourself without having to take it to a dealership right off the bat. The only way to fix the coils is to replace the injector since repair parts are not readily available for the injectors.
Old Mar 9, 2010 | 05:19 PM
harley boy's Avatar
harley boy
i agree whit npccpartsman for the wiring chafing
DRRXR
Oct 30, 2016 01:22 PM
jamiej780
Jun 25, 2014 02:48 PM
brandon.edwards
Feb 28, 2014 06:20 PM
2006powerstroke90
Jun 25, 2011 02:39 AM
