water pump failure???
Old Mar 8, 2010 | 09:02 PM
cheezit's Avatar
cheezit
you will find alot of things can be done with that simple tools. now there cheep enugh that its worth buying. I got mine when they were $200.00
Old Mar 8, 2010 | 10:30 PM
gb'sfx4's Avatar
gb'sfx4
old enough to know better
pressure test or flow test ? what will each tell me?
Old Mar 8, 2010 | 10:33 PM
cheezit's Avatar
cheezit
pressure will tell you if you have possible head gaskets or egr cooler or failed cap. flow may tell you why you have a problem. then you would go back to the pyro and check the system for cold spot for a lack of flow. if one spot is colder the the other theres the reason if all is the same temp suspect pump.
Old Mar 8, 2010 | 10:45 PM
gb'sfx4's Avatar
gb'sfx4
ok cold spots = blockage
thanx
Old Mar 9, 2010 | 09:30 AM
solaratomic's Avatar
solaratomic
I had no idea the wp in the 6.0 has a plastic impeller. Don't you just love when they go cheap on a $5K+ engine. Learn something new every day.
Old Mar 9, 2010 | 03:13 PM
bismic's Avatar
bismic
The interesting thing is that the proper plastic would truly be an upgrade due to less susceptibility to cavitation corrosion.
Old Mar 9, 2010 | 09:04 PM
gb'sfx4's Avatar
gb'sfx4
so if I want to upgrade to an 05 water pump,
i'm left holding the bag for the extra labor to do so?
unbelievable
Old Mar 9, 2010 | 09:05 PM
cheezit's Avatar
cheezit
to upgrade to a 05 water pump you would need a pump, front cover, and a lower radiator hose. still the same type of pump but for some reason they have less issues.
Old Mar 9, 2010 | 09:09 PM
gb'sfx4's Avatar
gb'sfx4
is the front cover behind the pump & how much extra labor to change it?
Old Mar 9, 2010 | 09:11 PM
cheezit's Avatar
cheezit
10 hours labor and like a 600.00 part. per the repair procedure you should remove the intake to replace the cover. it can be done other ways but thats another story.
Old Mar 9, 2010 | 09:14 PM
gb'sfx4's Avatar
gb'sfx4
that's kinda what I was thinking, thanx cheezit
Old Mar 9, 2010 | 09:22 PM
cheezit's Avatar
cheezit
sorry I could not provide a brighter outlook.
Old Mar 9, 2010 | 09:34 PM
  #28
gb'sfx4's Avatar
gb'sfx4
it is what it is , have not heard back from the dealer so I don't know for sure ,
what I do know is that I'm driving around with an 03 waterpump timebomb
Old Apr 26, 2012 | 10:34 PM
  #29
memarkers's Avatar
memarkers
so what was the outcome. Heres what I am dealing with. I was told by a dealer that my hgs are blown. The only problem I am having with the truck is the fan clutch is kicking on and off for no reason. At highway speeds the temp gauge goes fairly high then comes back down. No loss of power, no puking, no coolant loss and no white smoke or any smoke from the tailpipe. I changed the fan clutch thinking it was bad like it has before. I replaced the ect sensor. It did not help. I replaced the oil cooler and did the egr delete myself about 20K miles ago. Been running good. Just about had with the old beech. Anyone have any suggestions? How about a good independent mechanic in Dallas?
Old Jan 24, 2013 | 04:22 PM
  #30
bella dog's Avatar
bella dog
i would check the bottom radiator hose to see if it is collapsing. sucking together. the faster the engine turns the more it will suck together. it's like the thermostat being closed. the water will not circulate. so it will run hot .thanks ronnie
