no start
Old Mar 9, 2010 | 07:07 AM
colorado solar guy's Avatar
colorado solar guy
Sorry forgot to note that all fuses are good in both fuse boxes.
What kind of pressure at the schrader should I see:
Cranking?
Running?
Old Mar 9, 2010 | 07:52 AM
Action4478's Avatar
Action4478
Fuel pressure should be fine ,it re filled the bowl . You have a working WTS light , so the PCM is getting power . Is the CEL on? Running a chip?.. Batteries fully charged?
Old Mar 9, 2010 | 08:10 AM
CampSpringsJohn's Avatar
CampSpringsJohn
IDM?????????
EDIT: I see you have already tried that.
Old Mar 9, 2010 | 11:06 AM
colorado solar guy
Batteries charged, no CEL, stock except for exhaust, air intake and EBPV brake.
Had a no start on it about 6 months ago when a squirrel chewed off and removed about 2" of two wires at the firewall to the PCM. Checked my splice connections and they appear good.
In about ten seconds of cranking it put about an inch of fuel in the filter housing. I was told that should be good.
If it would have been easy, I would have already had it fixed.
Old Mar 10, 2010 | 07:51 PM
colorado solar guy
Pressure at the shrader valve is 36-38 psi. I had to put a street ell on the shrader to get a gauge on it. I tried checking it with just a tire gauge before I put the street ell on and it started and ran several minutes. Ran fine but shut down like it ran out of fuel. It would not start after I had a real gauge on it. Now what?
Ron
thendrix
18
Jan 14, 2017 09:52 AM
lindboep
Dec 1, 2015 01:39 PM
mechmagcn
21
Aug 23, 2015 07:31 PM
joe.d
Aug 14, 2011 06:56 PM
naturescape
Nov 26, 2009 11:30 AM
