VIN Bronco 81
Sorry, my english is too bad
Im from ArgentinaSoy Cesar de Argentina.
Tengo un Bronco xlt 1981.
Necesito decodificar el VIN de mi vehiculo.
En Ford.com solo esta disponible para modelos de 1996 al 2002.
Les envio mi VIN: 1 F M E U 1 5 G 8 B L A 3 4 7 3 8
Gracias
Cesar
E - GVWR/brake class 6000-7000lb hydraulic
U15 - Bronco
G - 302ci
8 - check digit; means nothing
B - 1982
L - Wayne, Michigan truck plant
A34738 - serial number
There is some other information in the codes on the sticker in the door jamb. If you e-mail me, I'll attach a Word document that will explain ALL the codes and show ALL possible values.
I found VIN of my BroncoCHECKED VIN 1FMEU15G8BLA34738
Description:
1 COUNTRY OF ORIGIN UNITED STATES
F MANUFACTURER FORD
M VEHICLE TYPE MULTI-PURPOSE VEHICLE
E GROSS VEHICLE WEIGHT 6,001 - 7,000 GVWR HYD
U15 SERIES U150 BRONCO 4X4 BRONCO
G ENGINE 5.8L (351CID) V8
8 CHECK DIGIT CHECKSUM OK
B YEAR 1981
L ASSEMBLY PLANT DETROIT, MI
A34738 SEQUENCE NUMBER IN RANGE
I found in www.autobaza.pl
Thank ou all
Cesar
