Need carb help
Old Mar 7, 2010 | 01:00 AM
MstrChief's Avatar
MstrChief
Need carb help
I am trying to figure out why the secondary’s on my Holly 4180 start leaking fuel with the butterflies closed whenever the truck drops to a slow idle. As soon as it does the truck keeps trying to flood out. When it does this, I can open the secondary butterflies just a bit and leans out the mixture and the engine revs up smoothes out and the leaking fuel stops... Until I let the secondary butterflies close, then the idle slows to normal, the fuel start leaking again and... Well you get the idea. I'm stumped.
It’s on my 84 F250 4X4 460ci 4 spd.<o></o>
Old Mar 7, 2010 | 10:28 AM
Old Hickory's Avatar
Old Hickory
Check the level of the secondary float and also check to see if the float is OK and isn't
gaslogged or has a leak. I run a 4180 on my 81 F100 and haven't had that problem.
If the carb hasn't been rebuilt in a long time it would be good to do it. If you do rebuild
it, use a Holley or Motorcraft carb kit.
Old Mar 7, 2010 | 11:04 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Yeah, that sure sounds like a float is sunk.
Old Mar 7, 2010 | 11:05 AM
BaronVonAutomatc
And whatever you do, don't try making one yourself out of styrofoam...
Old Mar 7, 2010 | 11:16 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Could be bad float, but I'd be more inclined to think it's needle/seat related. Either a bad needle/seat, or trash in it.
The only thing I like about holley carbs is the needle/seat assembly can be changed without carb disassembly.
boboh1
Apr 21, 2013 08:45 PM
72Truckin
24
Apr 15, 2013 04:41 PM
mad brad
Mar 15, 2013 08:02 AM
AmeriKen
Aug 27, 2005 11:24 AM
Thomsen
Mar 19, 2004 08:35 AM
