seats
Old Mar 7, 2010 | 01:00 AM
94cummins12v's Avatar
94cummins12v
seats
ok i picked up a set of 94 f250 front seats with center concel for 75bucks in perfect condition i want to yank my bench seet from my 91 f350 crewcab, how tough is it to mount the newer bucket seats in place of my current bench seat?
Old Mar 7, 2010 | 01:32 AM
tlk50's Avatar
tlk50
I can't answer your question but when you get it done let us know how it went. I have a 91 and want to upgrade the seat also.
Old Mar 7, 2010 | 03:01 AM
RCrawler's Avatar
RCrawler
If they were from a reg cab F250, they will bolt right in to the stock mounting. Extended cab floor pans are a bit different and will require some modification. Shouldn't be that difficult though.
Jason
Old Mar 7, 2010 | 08:46 AM
94cummins12v
no they did come out of a extended cab how much modification will be needed? to the mounting brackets or the floor itself. i just did a ford cummins conversion so i think im up to the task of swaping seats
Old Mar 7, 2010 | 01:00 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
i removed my seat from 96 supercab and it bolted right up exactly in place into my 93 reg cab.
this was a full bench to full bench swap tho.
Old Mar 8, 2010 | 09:25 AM
94cummins12v
oh got ya well im going to grab the seets hopefully tomarow so i will be able to look at it then
Old Mar 8, 2010 | 12:12 PM
Sycostang67's Avatar
Sycostang67
You will have to drill all new holes for everything. I suggest getting some large thick washers as well. The floors have extra metal where they bolt to the floor for each trucks seating arrangement. The washers will give a little extra support since you will be mounting your new seats on an area with out the factory reenforcement. I put buckets/console from a 90 into my 85 which had a bench. I just put the seats where I thought they should go and drilled the holes.
Old Mar 8, 2010 | 11:33 PM
94cummins12v
sweet thanks for the info i figured it shouldnt be to bad
Old Mar 11, 2010 | 02:10 AM
94cummins12v
got em in tonight hald to drill new holes but that was it
Old Mar 11, 2010 | 02:29 AM
rupejosh's Avatar
rupejosh
so when do we get to see some pics of this critter your workin on?ill be in your area tomorrow i sent you a pm
Old Mar 11, 2010 | 10:17 AM
94cummins12v
um ill get some more pictures uploaded on photobucet and get them attached to here so everyonecan see it
victor9909
Apr 14, 2015 10:49 AM
Cyco CK
WTB - Parts & other
Sep 29, 2012 04:10 AM
whenry912
Feb 11, 2011 07:47 PM
fzeed
Nov 1, 2008 10:32 PM
mdjohnson
17
Jan 23, 2006 05:58 AM
