Question on Seats
Old Feb 11, 2011 | 11:41 AM
whenry912's Avatar
whenry912
Question on Seats
Hey all
I have a 91 f250 Extended cab with split folding front bench seat.
I found a near perfect matching seat on CL, but it is from a 94 regular cab.
Can I put a regular cab non-split bench in my extended cab and will it fold enough to get in the back seat? Thanks!
Old Feb 11, 2011 | 12:12 PM
LCAM-01XA's Avatar
LCAM-01XA
You'll have to take both seats off their tracks, as reg cab and ext cab have different floor pan shape so reg-cab tracks won't fit your ext-cab floor. Other than that it should fit just fine, and if you cut the silly cable in middle of the seat back you'll be able to tilt it forward enough to hit the steering wheel with it (allows for very easy access to what's behind the seat).
Old Feb 11, 2011 | 01:15 PM
whenry912's Avatar
whenry912
Thanks for the info, the guy sold the seat already
Old Feb 11, 2011 | 02:18 PM
greywynd's Avatar
greywynd
Rather than cutting the cable, there's only one bolt on it anyway, just undo it and away you go. Used to do that with all my reg cab trucks, gave better access to the stray stuff behind the seat.
Old Feb 11, 2011 | 07:47 PM
tecgod13's Avatar
tecgod13
Damn that would have been a good idea to know! That cable always pissed me off because the seat would just want to fall back in place. So I'd have to hold it with one hand, and try and dig around with the other.
I fixed that problem by putting in a split bench from a 99 F150 extended cab. That required some modifications though...
david00f150
Oct 8, 2008 04:18 PM
mando jake
26
Feb 12, 2008 03:27 PM
Fordication
1997 - 2003 F150
Feb 29, 2004 09:32 PM
ranger1179
May 25, 2001 05:47 PM
