computer key!!!
Old Mar 6, 2010 | 08:56 PM
Skip1970's Avatar
Skip1970
computer key!!!
Went to walmart and had a key made, it would open the door but not start it, i think my 2000 excursion limited has a computer key!!!! i want to instlal remote start but i think they computer key is going to give me problems, how do i get around it?
Old Mar 6, 2010 | 09:43 PM
USMC616's Avatar
USMC616
When I looked at installing an alarm with auto start the installer asked if i had 2 keys, I said yes and he said that was a good thing since with 2 keys they could install some kind of device to mimic my key. He told me to program the device he needed 2 keys.
Old Mar 6, 2010 | 09:53 PM
Skip1970's Avatar
Skip1970
i was reading to tape one of your keys on teh drivers side behind the dash and it supposed to work.. then you can use any old key. but it defeats the purpose of the security i think.
Old Mar 6, 2010 | 10:57 PM
william_04_x's Avatar
william_04_x
Taping a key to the underside of the dash is a bad idea. Anyone with the inclination, and a sturdy screwdriver, would be able to roll off with your X. The PATS system is a great feature IMO.
Hopefully the key you bought at Wal Mart has a transponder in it.You can take it to Ford, or a good locksmith, and they can program it to your truck. It's a small price to pay for the security it offers.
And BTW:The Miser Bros Rule!!
Old Mar 6, 2010 | 11:11 PM
EXv10's Avatar
EXv10
B-uno; If you have one key with a transponder it will cost you at least $80 to make second one. Some hardware stores and most lock shops can do it. You may as well throw that Walmart key away unless you hide it outside of the truck in case you need to get in (best idea).
Old Mar 6, 2010 | 11:23 PM
william_04_x
I had a local locksmith delete a lost key from the system and cut/re-program a new key for $45. Shop around, you might find a deal.
Old Mar 6, 2010 | 11:38 PM
Stewart_H's Avatar
Stewart_H
Don't throw it away. If you have two workig PATS key's, you can just program that third key yourself.
I've posted these instructions quite a few times, but so you don't have to do a search, here they are again for ya!
Programming a PATS key:
1. Place first already programmed key in the keyway. Turn the ignition from OFF to ON (RUN) without starting the vehicle, for at least 1 second and then switch to OFF.
2. Within 5 seconds, insert your second already programmed key in the keyway. Turn the ignition from OFF to ON (RUN) without starting it, for at least 1 second and then switch to OFF.
3. Within 10 seconds of turning the ignition lock cylinder to OFF, insert the new key into the keyway. Turn the ignition from OFF to ON (RUN) without starting it, for at least 1 second and then switch to OFF.
The theft indicator light should go on for three seconds, after which the key will start the vehicle. Repeat this process, from the beginning, for each new key to be programmed.
Stewart
Old Mar 6, 2010 | 11:42 PM
Skip1970's Avatar
Skip1970
man maybe some locals can do it cheap for me, i will save the walmart one for when i lock the keys in it, and then i will also need to buy a device to allow me to use my remote starter on it.
its PATS
Ray
Old Mar 6, 2010 | 11:51 PM
Stewart_H's Avatar
Stewart_H
Huh? I just gave you the directions to do it yourself.
Stewart
Old Mar 6, 2010 | 11:53 PM
Skip1970's Avatar
Skip1970
Stewart
just one pats key, the other is a standard key.
Old Mar 7, 2010 | 12:55 AM
Stewart_H's Avatar
Stewart_H
Well, you didn't tell me that part!
My local OSH started doing PATS key cutting and programming for $70 bucks, IIRC.
Call around, ya might get lucky and find someone to do it for not a lot of cash.
Stewart
Old Mar 7, 2010 | 01:20 AM
EXv10's Avatar
EXv10
Stewart
That's why I said throw it away or better idea; hide it somewhere to get in. Walmart is not got to give him a transponder. They probably don't have one in the whole 589,787,593,890 square foot store and wouldn't recognize one if they were looking at it.
Old Mar 7, 2010 | 01:17 PM
Skip1970's Avatar
Skip1970
that guy is to much of a hot head!
Old Mar 7, 2010 | 01:38 PM
Quad411's Avatar
Quad411
Your kinda screwed, because you dont have that second key, but once you pay the high price for the 2nd key, do yourself a favor. Do like I did and go on e-bay, I got 2 blank pats keys for $15.00. Menards cut them for me free of charge. As far as the alarm goes. I bought a 05 excursion diesel in December. Last month, my dealer installed a prestige alarm with remote start. My pats system still works, and they didnt tape my key under the dash or anything like that. Unless you have a brand new 2010 that they havent come out with a bypass system for yet, your not going to loose your key.
Old Mar 7, 2010 | 02:12 PM
howler4x4's Avatar
howler4x4
Stewart
Thanks mate. I followed the directions in my manual (to a T), but no go. Your steps worked ASAP. Reps given
