computer key!!!
Old Mar 7, 2010 | 04:25 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by howler4x4
Thanks mate. I followed the directions in my manual (to a T), but no go. Your steps worked ASAP. Reps given
Thanks for the reps! Glad I could help.
Stewart
Old May 19, 2010 | 01:52 PM
Skip1970's Avatar
Skip1970
got a 2nd pats key 80$ later! hehehe now i need to get some off ebay and program them so this wont have to be expensive again!
Old May 19, 2010 | 07:21 PM
desertt5's Avatar
desertt5
I heard that AutoEnginuity can also reprogram them if you have at least one key. I have the AE, but never needed to try it yet.
Old May 19, 2010 | 08:26 PM
Skip1970's Avatar
Skip1970
damn it!! wish i would have known that! i would have put that 80$ towards the AE
Old May 19, 2010 | 08:28 PM
wallz's Avatar
wallz
Yes it can. It is cheaper to get a few from ebay stores, and sometimes you can get some of the key shops to cut and program for ya, even if you only have one key. (some of them have the technology)
I now have three working keys, one on my key chain, one on the wife's, and one hidden under the truck, just in case. Nothing like going fishing out of town and loosing a key, and not being able to get home. I have not done this yet, and don't want to try it out.
Old May 21, 2010 | 09:13 AM
vettdvr's Avatar
vettdvr
Just info for you folks.
My truck bought used came with only 1 pats key. I paid a locksmith $175 to make another after he read the codes with his computer.
Later my truck was in the shop for PCM failure. I told the shop buy new from Ford PCM. They bought from another supplier as it was about $250 cheaper. However the truck would not start due to the PATS system not matching the flashing of the PCM and Vin'#'s. Guess it thought it was stolen truck. The locksmith came back out to the truck location verified ownership and then reprogrammed the PCM/VATS system/ KEYS to work again. The cost was $275. so there was no savings on a aftermarket PCM vs new. If you ever need a PCM get one where your flash program is installed on the replacement. Junkyard PCM's will cost you much more to get flashed and matched to VATS.
Correct. If you have 2 keys you can program a 3rd. If you only have 1 key get out your wallet.
Old Jun 25, 2010 | 05:02 PM
Bob 2011 F250's Avatar
Bob 2011 F250
Question More PATS key problems.
I am having related key problems in my new truck. I hope this is the correct place to ask my question. I am new to forums of any type.
I bought 2 new keys from the local Ford dealership for my 2011 F250 Lariat ($60 ea). I followed the instructions in the owner’s manual (they are the same as you listed earlier). It says that if successful the new key will start the engine and the theft indicator will go out. Neither of the keys will program. The manual says that if they will not work take them to the dealership and have them do it for you. The reason I am doing this before I lose a key is to avoid paying the dealership for the service. Incidentally my old 2002 F150 had a red indicator that said “antitheft” the 2011 owner’s manual refers to the indicator but I can’t find anywhere.
When I try to use one of the new keys that the computer doesn’t recognize, the little computer screen between the Speedometer and the Tachometer displays “Starting System Fault” in red letters instead of a compass. A couple of times while I was going through the three key routine the electric door locks clicked twice.
Any Ideas?
Old Jun 25, 2010 | 05:11 PM
vettdvr's Avatar
vettdvr
Any Ideas?
If they sold you the correct keys you have a problem with the truck given you followed the procedure in the owners manual. They should fix the truck.
If they sold you the wrong keys they should replace them. Hopefully you bought the keys at the dealer where you bought the truck.
Old Jun 26, 2010 | 05:51 AM
Bob 2011 F250
Post
Thanks,
Not the same dealer as I bought the truck from, they are closer but have earned a bad reputation with me. I thought something as simple as a couple of keys would not be a problem.
Old Jun 26, 2010 | 07:11 AM
vettdvr's Avatar
vettdvr
Thanks,
I learned a long time ago nothing is ever simple until it is completed.
Old Jun 26, 2010 | 02:17 PM
EXv10's Avatar
EXv10
My truck came with 1 key and they used it at Ace hardware store to make another one for $80.
Old Jun 26, 2010 | 06:27 PM
Skip1970's Avatar
Skip1970
what im wondering is when they make you a 2nd key is it a duplicate of the first exactly? or does it get a new piece of info inside the computer?
Old Jun 26, 2010 | 06:35 PM
  #28
EXv10's Avatar
EXv10
They call is a clone and it must be because there is no reason to add more info to the computer,
Old Jun 26, 2010 | 10:54 PM
  #29
Skip1970's Avatar
Skip1970
well i hope its different because to program another key you need to different keys i believe. right?
Old Jun 26, 2010 | 11:19 PM
  #30
Moto Mel's Avatar
Moto Mel
Any Ideas?
If the door locks clicked and then the keys didn't work you must have skipped a step in the procedure. Read and follow the instructions again, slowly.
