Trimming a 2005 grill
Old Mar 6, 2010 | 07:46 PM
fordex2003's Avatar
fordex2003
Has anyone trimmed a stock 2005 grill to fit a 200-2004? I see them for sale for 63.00 vs 350.00 for the already trimmed conversion grill. How difficult can it be?
Old Mar 6, 2010 | 08:56 PM
broncorif's Avatar
broncorif
Do a search in the forum. I found a complete write up with pictures and measurements. I ended up modifying a 2005 basic black plastic grille and it worked out nicely. The instructions were easy to follow. I don't have the link anymore, but if I come across it again then I'll add it to this post.
I recommend giving it a try. If you can use a measuring tape and a dremel tool then it's an easy modification.
Old Mar 6, 2010 | 09:38 PM
TYZ78F150's Avatar
TYZ78F150
Where did you find the 05' grill for $63.00? Does it already come with the black honeycomb and blue oval FORD?
Old Mar 6, 2010 | 11:05 PM
2002 F350V10's Avatar
2002 F350V10
The 05-07 grilles are taller. To fit you need to cut across the bottom , and the lower angled sides. Then there is no way to fasten the lower part of the grille. Only the 4 screws on the top are the same.
Old Mar 7, 2010 | 07:04 AM
fordex2003's Avatar
fordex2003
05-07 FORD F250 F350 SUPER DUTY GRILLE BLACK HONEY COMB : eBay Motors (item 170269265004 end time Mar-29-10 05:52:49 PDT)
This is the one I was going to buy. I want mine painted and this is already primed.
pkthomas
May 6, 2017 09:17 AM
Crims
Sep 28, 2016 03:12 PM
firstrider
Jan 17, 2016 08:48 PM
clintonvillian
Feb 3, 2014 09:25 PM
superdutyaz
Jul 14, 2004 12:58 PM
