97 explorer fuel pump replacement
Old Mar 6, 2010 | 06:46 AM
gvrangr98's Avatar
gvrangr98
Question 97 explorer fuel pump replacement
Hey guys,
Looking to replace the fuel pump in a 97 ford explorer 4x4.
It is a 4.0L VIN "X" .
I was hoping someone could point me in the right direction to purchase the part.
Is it a modular pump design? I am confused because When I "googled" it The picture show both a small electric motor and a modular design.
Which one is right for me? thanks.
Old Mar 6, 2010 | 03:49 PM
trimman's Avatar
trimman
I have also a 97 and God willing it won't have any more problems than it already has. Met a buddy of mine today that has a 95 that just had his pump replaced at a cost of $800? Glad to hear your trying to do this yourself. Good luck with your search.
Old Mar 23, 2010 | 08:36 PM
Youngbuck887's Avatar
Youngbuck887
what you were probably seeing on google was a picture of just the fuel pump itself which is actually located inside the modular design. as for buying the part i would recommend just going to a junkyard and buying the whole modular sender as a unit. it would probably be the cheapest easiest way to go.
Old Mar 24, 2010 | 06:36 AM
gvrangr98's Avatar
gvrangr98
ended up being the tube in side the tank that connects to the pump. the fuel inlet line had ripped, causing the fuel to shoot back into the tank instead of up to the engine. I replaced the fuel pump. found a used one at a bone yard.
onug
2015 - 2020 F150
Jan 8, 2017 09:29 PM
bluff3
Apr 21, 2016 09:18 AM
gman97005
Jan 13, 2016 11:38 AM
countrygirl37
Aug 15, 2012 10:25 PM
TX76F250
1997 - 2003 F150
Aug 22, 2011 11:19 AM
