Carb swap
Old Jan 22, 2003 | 09:13 AM
f150johnny's Avatar
f150johnny
Talking Carb swap
ALL,
I have a 82 F150, 351w, Variable Ventrui carb that I am sick of. I'm looking to replace this carb with a regular venturi carb, with electric choke, and would like some inputs and ideas that would afford me some insight on what is best. I'm looking to optimize fuel performance on the highway. I'm not looking to whiplash myself off the line, but I guess you could say that a little pep is always good.
The wife says she is gonna foot the bill (cause its my birthday) for the carb, but I'd still like to make an educated, cost effective decision. I've not isolated myself to any particular make/ model is just want something that work well in all situations...
Any suggestions will be greatly appreciated.....
Thank You ,
Old Jan 22, 2003 | 11:17 AM
johnsonacres's Avatar
johnsonacres
Carb swap
That carb, is a 2v or 4v?
Old Jan 22, 2003 | 01:10 PM
f150johnny's Avatar
f150johnny
Carb swap
never thought to look....I'm gonna have to say 2v. Do you mean to tell me that Ford acutally made a 4v carb?
Old Jan 22, 2003 | 05:32 PM
Franklin2's Avatar
Franklin2
Carb swap
Can your wife afford $400.00? If so, this is what I would get.
Old Jan 23, 2003 | 07:20 AM
f150johnny's Avatar
f150johnny
Carb swap
Franklin,
Thats about the price range I mentiioned to her.....do you have model numbers and or a description for both the carb and intake? Also, where to find them would be another good piece of info.....
Hey is this carb and intake your personal choice, is it something you have on any one of your vehicles?
Thanks again,
Old Jan 23, 2003 | 10:25 AM
xuare's Avatar
xuare
Carb swap
The intake looks like an Edelbrock Performer intake (square bore) without EGR
The carb is a holley 4 barrel of some kind (franklin needs to answer). I'd guess in the 600 cfm range
Old Jan 23, 2003 | 12:11 PM
Franklin2's Avatar
Franklin2
Carb swap
You can go to www.summitracing.com or www.jegs.com. There may be some places cheaper than these, but I don't know of them.
If you go to summit racing;
click on online catalog in the upper left corner.
click on "air and fuel delivery"
click on "carburetors"
click on "Holley 4160 four barrel carbs"
click on "HLY-0-1850S."
I do have personal experience with this carb, and it has always performed well on my Fords. It has manual choke, so you will need to mount a cable under the dash. I like this feature, but if you don't, for a little bit more money you can buy one with electric choke(look a little lower down on the carb screen). I have also heard good things about the edelbrock carbs, but I have never run one. But I bet it would do fine.
Back up to "air and fuel delivery" and then click on "intake manifolds and acc"
click on "edelbrock performance intakes"
click on performer series.
I have no experience with this particular manifold. I have run edelbrock manifolds on other engines, and they work fine. I just picked this one so the above carb would fit. If you wanted to hunt around for a used manifold, a truck or bronco with a 351HO would have a factory manifold that would let the carbs above bolt on.
Just remember there will be some stuff (hoses etc) that will have no place to go if you use the above set-up. All you really need is one hose to the distributor, one hose to the PCV valve, and one hose to the original aircleaner set-up, which I would use. I like keeping the original aircleaner for the hot air feature on the snorkel, and it makes the engine look more original for inspection purposes.
Old Jan 24, 2003 | 03:38 AM
pbrstreetg's Avatar
pbrstreetg
Carb swap
Here's my advice F150Johnny-
If you need a four barrel manifold the performer is the perfect best choice like these guys are saying. But the carb choice- I love Holley carbs, but if you don't then get an Edelbrock. You'll be happier( trust me).
khaospirate
Mar 10, 2011 07:02 PM
AZ4x4f150
General Automotive Discussion
22
Feb 8, 2007 02:58 AM
66F100Again
Jan 18, 2007 08:37 PM
truckman79
Sep 13, 2003 09:38 PM
hflu
Feb 6, 2002 09:35 PM
