Voltage Regulator Problems
on
I like the 3G better for a couple reasons,
#1 it's still a ford part haha
#2 they are very easy to wire up. Of the 4 required wires only 2 come off the alternator. ( charge cable and exciter wire)
#3 they can be had for dirt cheap at any JY.
#4 it's a stock part, so if your ever out on the road you can find a replacement easier.
#5 they put out more amps.
ive repaced battery alternator and voltage regulator with stock replacement parts and still no charging. My printed circuit going to my amp gauge is burnt. Is there anyway i can bypass the gauge all together since it never worked
If the light doesn't work, put switched power to the "I" terminal of the external regulator.
I'm pretty sure trigger voltage goes through the light circuit then to I terminal.
Maybe someone will verify by tomorrow.
But you can look up the wire diagram diagram for a stand alone external regulator and probably verify.
websurfer
1997-2006 Expedition & Navigator
19
02-21-2024 06:19 PM
AZRogala
Computer Chips & Tuners
17
12-11-2015 04:30 PM
clarkbre
04-28-2014 10:40 PM
