Voltage Regulator Problems
Old Apr 29, 2014 | 06:01 PM
351Cleveland C4's Avatar
351Cleveland C4
I like the 3G better for a couple reasons,
#1 it's still a ford part haha
#2 they are very easy to wire up. Of the 4 required wires only 2 come off the alternator. ( charge cable and exciter wire)
#3 they can be had for dirt cheap at any JY.
#4 it's a stock part, so if your ever out on the road you can find a replacement easier.
#5 they put out more amps.
Old Jun 4, 2018 | 08:55 PM
YazooWill's Avatar
YazooWill
What can I do since my printed circuit it burnt alternator still not charging
Old Jun 4, 2018 | 09:26 PM
UNTAMND's Avatar
UNTAMND
Not quite sure what you said...
What alternator is in your truck currently? What have you done to try and fix it?
Old Jun 4, 2018 | 09:37 PM
YazooWill's Avatar
YazooWill
ive repaced battery alternator and voltage regulator with stock replacement parts and still no charging. My printed circuit going to my amp gauge is burnt. Is there anyway i can bypass the gauge all together since it never worked
Old Jun 4, 2018 | 10:12 PM
UNTAMND's Avatar
UNTAMND
If the light doesn't work, put switched power to the "I" terminal of the external regulator.
I'm pretty sure trigger voltage goes through the light circuit then to I terminal.
Maybe someone will verify by tomorrow.
But you can look up the wire diagram diagram for a stand alone external regulator and probably verify.
Old Jun 5, 2018 | 06:32 PM
Thipdar's Avatar
Thipdar
You'd probably be better off to start a new thread for this.
Old Jun 13, 2018 | 06:44 PM
JEFFFAFA's Avatar
JEFFFAFA
2X.
And one thing you can answer on the new thread is if your truck came with an idiot light cluster and you installed a gauge style. They are wired differently.
websurfer
19
Feb 21, 2024 06:19 PM
AZRogala
Computer Chips & Tuners
17
Dec 11, 2015 04:30 PM
clarkbre
Apr 28, 2014 10:40 PM
Hawk180
Dec 21, 2012 08:06 AM
d5332
1997 - 2003 F150
Oct 22, 2010 11:25 AM
