94 E350 5.8 throttle body HELP!!!
A customer brought this van to me in pieces stated that a "friend" was working on it, Anyway I have it all back together except I cannot locate where the top cooling hose on the throttle body connects to the bottom one connects off the heater hose behind the t-stat on the intake but for the life of me I cannot figure out where the top one goes Thank You !!
It is a short rubber line that is connected to a metal line that runs down the passenger side of the engine. It connects to a couple of water pump bolts and also the timing mark bracket. It then switches back to a rubber line and connects to a port on the bottom of the radiator.
You can see it fairly well in this picture:
Dave
Dave
Dave,
Thank you for the info. The customer brought this in as a basket case and that piece was missing along with the nipple in the radiator. Seem the cust went used rather than new.Maybe I can get away with a hoses.
Last edited by rocketwrenchbender; Mar 7, 2010 at 10:21 PM. Reason: misspelled works
gman97005
Air Intakes, Air Filters & Ram Air
Jun 6, 2016 11:09 PM
THE BLUE BEAST
6.4L Power Stroke Diesel
Feb 18, 2014 08:56 PM
