92 Flareside when getting gas....
Old Mar 5, 2010 | 06:46 AM
nflfreak43's Avatar
nflfreak43
ok this has been bugging me for well ever since i got my truck in January of 09... how many other people have problems with getting gas in there Flaresides? i have to put the nozzle at a really cockeyed angle and only let it flow bout half speed or else itll shut off like its full.. now is it just how the fuel filler hose is angled or is it something wrong... i have looked at the hose but it dont look kinked up or anything... any ideas???
Old Mar 5, 2010 | 06:50 AM
93MARKIII's Avatar
93MARKIII
i have a '93 flareside, just filled up yesterday for the first time and didnt have any problems, that was on the front though, havent tried the rear yet.....
i know what your talking about though, ive had a couple of cars over the years that you had to hold the nozzle in just the right way to get the gas to flow
Old Mar 5, 2010 | 06:53 AM
nflfreak43's Avatar
nflfreak43
i always use the front as my rear tank has a leak... crap i forgot bout that... dayum another thing to do....
Old Mar 5, 2010 | 07:49 AM
TexasGuy001's Avatar
TexasGuy001
I sometimes have that problem with the rear tank on my truck.
Old Mar 5, 2010 | 09:55 AM
cjben's Avatar
cjben
no problems with my 95 flareside.
Old Mar 5, 2010 | 12:15 PM
TexasGuy001
I think the issue has to do with the inner hose in the filler neck. It partially collapses I have heard.
Old Mar 5, 2010 | 01:32 PM
fishforlife2007's Avatar
fishforlife2007
ive got a 95 flareside. i only have a single tank, but never have any issues when it comes to fueling
Old Mar 5, 2010 | 01:37 PM
86F150302's Avatar
86F150302
Ive had that problem with both my trucks.
I see that it doesn't do it when I don't have the pump on "lock" I think the gas goes in too fast and splashes back up shutting off the pump.
I also pull the nozzle out about halfway and it seems to work fine.
Old Mar 5, 2010 | 03:23 PM
*2fords*'s Avatar
*2fords*
I've never had that problem with my 92 flairside on either tank.
Old Mar 5, 2010 | 04:59 PM
95stepside's Avatar
95stepside
i have that exact problem on my 95 flareside
Old Mar 5, 2010 | 05:14 PM
blueeyedfordguy's Avatar
blueeyedfordguy
I own a styleside not a flareside. My 1988 f150 with a 302 v8. The front tank does not work. the rear does. When I bought it, the left leaf springs where bad, so It sat at a very aukward lean. About 10 inches different when you measured the bumper from the right to the left. Very tough to get the gas in. If you poured it in with a gas can, it would act like it was a clogged drain on a sink and not go down very well at all. So, I would keep my back straight. grab the bumper, and lift up this would make it accept gas. I've fixed the leaf springs since then, and it still does it now and then. But, not NEARLY as bad. I click the gas nozle at the pump to the slowest setting, and it will stop at a dollar or two. When I play with the fuel trigger it will start accepting gas with in a few minutes. I've heard there is some valve that prevents the gas from going down into the tank. Thats my experiences and 2 cents. Other wise I have rarely had this happen with other vehicles.
Old Mar 5, 2010 | 06:23 PM
SaikotikGunman's Avatar
SaikotikGunman
Our '87 styleside does the same thing with the rear tank. On the pumps in town, with three notches in the latch, I could never get it past the first one.
Old Mar 5, 2010 | 08:27 PM
blueeyedfordguy
yeah, mine does it on the rear as well. I'm not in a huge hurry though. That is, im not in a hurry to spend a lot on gas
Old Mar 5, 2010 | 09:34 PM
SaikotikGunman
On the other hand, if I left the truck running while I was filling it, I'm pretty sure I'd use gas faster than I put it in.
Old Mar 6, 2010 | 05:39 AM
blueeyedfordguy
yeah, im never in a large hurry at the pump. I just pump it slow, and if it acts like its full I just gotta mess around with it for a minute.
