I found a deal on a manual off another truck. I might be able to get the manual tranny cheap. Does any one know if the tranny will fit a 7.3 off a 6.0? As a personal preference i just want my manual back that i have had in the past.
All the 7.3 turbo trannies interchange as far as bolt patterns. The blocks were all the same. From what i have read if you go from auto to manual you can use the same pcm. If you go from manual to auto you have to change it. If you switch an old body style and new body style auto trannies you will also have to change pcms. Hopefully some one else will come verify that.
now will a 04 6.0l transfer case fit behind a 7.3 auto's 4x4 trans.
becouse im wanting to go 4x4 i have the front end complete just need to bolt up and i have the option of getting the transfer case too for 300.? JUST NEED TO KNOW IF IT WILL WORK?
