Help With Wiring
Old Jan 15, 2005 | 02:26 PM
Ford427Strokr's Avatar
Ford427Strokr
Help With Wiring
Will a manual engine harness work with an automatic transmission. I am trying to use a manual harness off a 95 truck in a 92 truck with an E4OD tranny. Where could I find wiring diagrams for this? Thanks
Old Jan 15, 2005 | 03:06 PM
fefarms's Avatar
fefarms
If you want the E40D to shift, you need a computer that can operate it, and the appropriate wiring from the computer to the trans.
You could probably use portions of a 95 manual trans harness to replace portions of the wiring between the computer and the engine. You can't use the 95 computer, unless you make other provisions to shift the trans (like a stand-alone Baumann trans computer). You have to splice the 95 harness pieces AFTER the 60 pin connector, because that connector supplies both the engine and trans.
This is one situation where an alldatadiy subscription might be worth the money, because you can get the wiring diagrams for both the original and donor trucks relatively cheaply ($24.99 for the first truck and $14.99 for each one after that). This project is a "considerable assembly required" and is not for the faint of heart.
Old Jan 23, 2005 | 10:52 AM
Ford427Strokr
I have a VEX1 computer and I have found a mustang mass air wiring harness that splices into the original harness. I am wondering if the pin connections are the same. I think it will work assuming all trucks wether they are sd or mass air have bank to bank injector firing orders.
Old Jan 23, 2005 | 07:10 PM
EPNCSU2006's Avatar
EPNCSU2006
Factory mass air trucks are sequential injection.
AMERICA_
Mar 17, 2015 10:27 PM
97powerstrokemaniac
Feb 11, 2013 04:01 AM
ReAX
Electrical Systems/Wiring
19
Oct 3, 2006 06:47 PM
bjoern
Apr 4, 2002 12:21 AM
