Need help quick; 6637 mod
Old Mar 4, 2010 | 03:04 PM
FallstonYJ's Avatar
FallstonYJ
I am right in the middle of installing the 6637 intake mod and I need some help. I have taken out the stock filter box and have the filter sitting in place but there is no way the hood will close. The hood starts pressing down on the filter when it is several inches from being totally closed. Do I have to remove the entire tray that was under the stock filter box as well? If so I guess that means pulling the battery?
Any quick help would be greatly appreciated; I need to get this completed tonight; trailering my jeep up to Rausch Creek tomorrow for a weekend of crawling.
Oh, 2003 Excursion EB 7.3TD.
Thanks for your time,
Tom
Old Mar 4, 2010 | 03:06 PM
patrickke's Avatar
patrickke
who did you buy this from? Clay?
superduty4x4's Avatar
superduty4x4
Did you remove the lower half of the stock airbox? If not do that. If it still won't work, get out a Dremel or a hacksaw and cut out the portion of the OEM battery box that was under the stock airbox.
Old Mar 4, 2010 | 03:07 PM
patrickke's Avatar
patrickke
if It is Clay Id call him and ask do a search and look for the instructions and you may find pics with them that will help you out
Old Mar 4, 2010 | 03:09 PM
clem1226's Avatar
clem1226
I removed my whole battery tray, took a sawzall to the reminant of the airbox that is attached to the battery tray and reinstalled.Took maybe 20 min.... Fit like a dream.
Old Mar 4, 2010 | 03:11 PM
Trucky2's Avatar
Trucky2
I ran up against the very same thing on my install. Talking to Clay I learned there are 3 variants there.
1. It fits fine, no mods needed.
2. You have a two piece battery holder/bottom tray and a few screws will let it pop out.
3. You have a one-piece battery/bottom tray and have to pull the battery and tray assembly and take a sawzall to the connecting part to separate and still maintain the battery tray.
I had 2. but couldn't really tell till I had the battery out, which made it easier to work on anyway. It was also a great time to clean up my battery posts and get a bit of Liquid Film on the terminals.
Old Mar 4, 2010 | 03:15 PM
guitarpicr's Avatar
guitarpicr
Dumb ? - But Will turning the rubber boot(pivoting it) from the turbo help- Mine hit the hood when I first installed it till I did this, Now its fine. Good Luck- let us know how it works out
Old Mar 4, 2010 | 03:26 PM
FallstonYJ's Avatar
FallstonYJ
Thanks for all of the quick replies guys; I really appreciate it!
I did remove the bottom half of the stock box and I did turn the rubber boot but it is still too high. I was afraid the battery tray had to go but I just wanted to hear it from experience. I'll get right on it!
Thanks again, Tom!
sowaxeman
Jul 30, 2014 06:01 PM
Justin03PSD
Apr 1, 2012 09:33 AM
SSSimon
17
Aug 13, 2010 04:44 AM
mechelement
15
Sep 5, 2009 08:18 AM
JustinSWeber
17
Jan 8, 2008 06:31 PM
