I have a 2000 F-350 Cab/Chassis. I want to attach a universal gooseneck plate (Carry-On trailer makes a universal gooseneck plate #805) to the actual frame rails (the truck does not have bed/flatbed on it). My question is: Are there any welding or drilling issues that I should be aware of? I prefer to NOT do a lot of drilling into the rails as I have heard that can cause some issues. There are a couple of holes already punched that I will probably put some Grade 8's down there but I am also wondering if I can make those holes a bit bigger (from 3/8" to 1/2" holes). I am also considering putting some welding into the plate after bolting it down. Any thoughts or suggestions are appreciated. Thanks.
I don't think drilling a couple holes out an additional 1/8" is going to hurt anything, and as long as you are a competent welder I think you're OK there as well. Having said that, I would be very careful to place the ground lead as close as possible to the weld and disconnect the battery when welding on any chassis.
...I would be very careful to place the ground lead as close as possible to the weld and disconnect the battery when welding on any chassis.
Yes, I wouldn't put the welding lead more than a foot away from where I was working on that truck, there's been cases of the airbags going off from placing the grounding lead at the front and welding on the rear...
I didn't know that, but it's good to know. I've learned from other welder's mistakes about the ground lead thing. Occasionally one of the guys at work will get lazy and ground a structure very far away where it's convenient, then weld where necessary. The problem is the current may have to travel through such things as extremely expensive bearings and/or electrical circuit boards which leads to expensive welding lessons and upset supervisors.
