Testing Block Heater
Old Mar 4, 2010 | 09:50 AM
baddarryl's Avatar
baddarryl
I think the block heater in my 91 7.3 has burned up. Plugged in all night and the engine is cold. Not even any warmth on the heater end of the power cord. Stuck in the drive! Thanks.
Old Mar 4, 2010 | 10:08 AM
starmilt's Avatar
starmilt
A lot of the times the problem is where the plug attaches to the cord. If you unplug it and plug it back in you will se a spark or hear it when you start plugini it in.
Old Mar 4, 2010 | 07:39 PM
baddarryl's Avatar
baddarryl
No sign of that really. I do know that the truck side of the cord did use to get warm to the touch. Is that normal?
Old Mar 4, 2010 | 07:56 PM
Coalroller's Avatar
Coalroller
try doing a resistance test on the male end of the plug thatll tell ya if it is the cord or the element
Old Mar 4, 2010 | 10:44 PM
baddarryl's Avatar
baddarryl
What should that resistance be? Thanks.
Old Mar 6, 2010 | 01:42 PM
Coalroller's Avatar
Coalroller
sorry bout waitin so long to get back to ya if you have a volt meter set it the 20 on the ohm and touch the 2 top pins on the male side of the block heater cable and if there is any resistance than it is good if not than you need a new cord
Old Mar 6, 2010 | 03:23 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Block heater come in a variety of wattages.
Because of that, resistance can vary.
26.4 ohms = 500 watts
13.2 ohm's = 1000 watts
8.8 ohm's = 1500 watts
That is three examples, I have seen 600, 750, 900, 1200 and several other wattages over the years on top of the ones I listed above.
Old Mar 6, 2010 | 08:08 PM
baddarryl's Avatar
baddarryl
With my ohm meter set at 200 (the lowest I can get it) I get no response at all. I tested it on an air compressor plug with the same setting and it did read. That mean I need a new cord?
Old Mar 6, 2010 | 09:25 PM
Coalroller's Avatar
Coalroller
yes and your local napa store will have them or can order them in they are either a 5 foot or 6 foot cord no more than $20 i believe mine was $15 when i got mine. it is much more common for the cord to go bad than the actual heating element itself
Old Mar 6, 2010 | 10:14 PM
baddarryl's Avatar
baddarryl
Thank you.
Old Mar 7, 2010 | 12:33 AM
tlk50's Avatar
tlk50
Unplug the cord from the block heater and bench test it. I've found many of these cords break right at the male end you connect to the extension cord. If it has continuity check the freeze plug for continuity. Sometimes the cord is not making good contact with the freeze plug prongs. If the freeze plug shows 0 continuity replace it. I use a 600 watt up here. It warms up my old 1984 6.9 or my 1991 7.3 enough in 30-45 minutes to start at -20.
Old Mar 7, 2010 | 11:42 AM
Dave Sponaugle
I second the check the heater before buying just a cord.
If you buy the cord, then have to replace the block heater, you will wind up with two cords.
Old Mar 7, 2010 | 03:13 PM
baddarryl's Avatar
baddarryl
Hi Dave. What is the test criteria for the heater itself? Thank you.
Old Mar 7, 2010 | 07:52 PM
Coalroller's Avatar
Coalroller
sorry i got ahead of myself, yes i did skip that step of checking the block heater while the cord was unplugged from it thanks dave
Old Mar 7, 2010 | 08:58 PM
Dave Sponaugle
Check the ohm's across the connections at the block heater.
Common block heater wattage resistance values in post #7.
