holy smoke
Old Mar 4, 2010 | 11:05 AM
utjer's Avatar
utjer
https://www.ford-trucks.com/forums/4...egr-valve.html
Here are the instructions on how to do it with pics. It is pretty easy, only two bolts.
Old Mar 4, 2010 | 11:06 AM
1_BIGMOFO's Avatar
1_BIGMOFO
sweet! Thanks! I will give it a shot today! You guys are great!! Thanks again!
-worst case scanario... whats this going to cost me?
Old Mar 4, 2010 | 04:02 PM
Rush117's Avatar
Rush117
The service advisor told me that he is not supposed to give me any paperwork with the breakdown of the warranty work. So I found a little birdie that was quite helpful. Here's the cost breakdown that the little birdie gave me:
EGR Cooler 4C3Z9P456AF: $410.06
Oil Cooler 3C3Z6A642CA: $252.00
Oil Cooler Screen 3C3Z6C683AB: $8.62
VC-9: $22.26
VC-7B: 2 @ $13.99 = $27.98
Air Inlet Connection 6C3Z6C640B: $50.34
Air Inlet Connection 6C3Z6C640A: $55.85
Total Parts: $827.11
Labor: 10.9 hours @ $89.82 = $979.04
Total Cost: $1,806.15
I don't know what the going rate is for a diesel tech. I'm sure $89.82 is the rate Ford pays for warranty work. I'd expect a customer rate to be higher. Maybe Cheezit will stop by this thread to give you a good number. Either the rate will be higher or the billed hours will be higher.
The service advisor told me that they also reconditioned the turbo and reflashed the truck but that is not in any of the paperwork that the little birdie gave me.
If the EGR or Oil Cooler is your problem, then I'd just delete the EGR rather than replace the cooler. Just be sure to check out your local emissions laws before you do such a thing. I was going to delete the EGR as soon as the warranty expired but I guess I'll save the expense for a couple of years since I have new parts. I'll delete it later.
Good luck finding another job. Sounds like the timing of this could not have been worse.
Old Mar 4, 2010 | 09:22 PM
1_BIGMOFO's Avatar
1_BIGMOFO
thanks a ton for the info. Whats a good EGR delete kit cost and where is the best place to get one? I think it may be something worth doing even if thats not the problem.. right?
Old Mar 5, 2010 | 08:07 AM
Sarge261's Avatar
Sarge261
PM me and I can help you out if you need the EGR cooler deleted and the oil cooler rebuilt.
The kit from first coast diesel looks good, and as of right now there is no talk of emmissions testing diesels up here. If you are worried about it in the future look into the bullet proof EGR cooler.
Sarge
Old Mar 5, 2010 | 08:17 AM
1_BIGMOFO's Avatar
1_BIGMOFO
I just PM'd you about getting that other work done we talked about. I will have the truck checked out when its at your place next week and we can talk then. Thanks a ton man! I appreciate the help very much!!
caere
May 28, 2013 07:32 AM
1_BIGMOFO
Nov 21, 2010 09:26 AM
eric777
Sep 10, 2009 07:22 PM
cartmanea
May 30, 2009 08:26 AM
WWBeast
Apr 16, 2009 09:13 PM
