Trans removal help
Old Mar 3, 2010 | 07:21 AM
fmfire672's Avatar
fmfire672
Trans removal help
A buddy of mine brought his F1502wd truck over to have me help pull the trans out. He lost overdrive. I was wondering if you had to remove the exhaust where it crosses over behind the trans. It has the 4.6 motor I believe. thanks for the help
Old Mar 3, 2010 | 12:00 PM
Twinsdad98's Avatar
Twinsdad98
You shouldn't have to. If you are removing the trans cross member, you should have enough room to get the trans out without removing the y pipe.
Old Mar 3, 2010 | 01:31 PM
fmfire672's Avatar
fmfire672
Thanks Twinsdad98, I have it on my lift now, it looks close! I will give it a try.
blakeusa
Dec 31, 2013 03:33 PM
65fstback
19
Nov 2, 2013 05:05 AM
remmers
Nov 3, 2009 07:28 PM
ftm 350
Bronco II
Aug 22, 2003 09:13 AM
