Steering Stabilizer
Old Mar 2, 2010 | 06:43 PM
mike brez's Avatar
mike brez
Steering Stabilizer
looking for a dual steering stabilizer set up wondering if anyone is running one and how you like it.
Old Mar 2, 2010 | 08:40 PM
WideOpenFord's Avatar
WideOpenFord
bump..... im lookin for some to, just got bilstein 5100's and wanted there matching stabilizers but i cant seem to find them.
Old Mar 2, 2010 | 08:51 PM
RussB's Avatar
RussB
Lots of kits hang down where the stock one is mounted... if you use your truck off road at all it will get hit eventually. I've bent a couple of them... I do know that rough country makes one that appears to sit a little higher due to the use of aftermarket brackets.
Thats all I can help ya with there.... sorry
Old Mar 2, 2010 | 08:58 PM
mike brez's Avatar
mike brez
I was leaning towards this one 99-04 Ford Super Duty F250/F350 Dual Steering Stabilizer Kit with Bilstein Cylinders - Top Gun Customz and it uses the 5100 shocks little pricey though.
Old Mar 2, 2010 | 09:25 PM
RussB's Avatar
RussB
It looks like those brackets might mount it up a bit higher as well.. Nice looking kit... I'd look into that a bit further. The price isn't all that bad actually !
Old Mar 2, 2010 | 09:33 PM
mike brez's Avatar
mike brez
I was looking at this one first Rough Country Ford Super Duty Dual Steering Stabilizer Kit 99-07 4WD - AutoTruckToys.com but seems to cheap. looks like it mounts up fairly high.
Old Mar 2, 2010 | 09:48 PM
Benny2002's Avatar
Benny2002
Ive used the beefed up single damper from Fabtech and the opposing style from skyjacker. The single really is plenty for function but the opposing looks cooler. Ironically they both only really last for about 25-30K. Which is annoying but cant speak for the bilstiens probably last longer. Makes your steering a little stiffer on the opposing style.
WideOpenFord
i already have the dual mounting brakets just needed stabils to match my shocks, it would look weird with bilstein shocks and rough country stabils, but i found some thanks for the site Russ
(2) Bilstein 5100 Series Upgrade Cylinders Dual Steering Stabilizer - Top Gun Customz
Old Mar 2, 2010 | 09:52 PM
WideOpenFord
yea but the big picture they show is for the newer 05-07 front ends click the small bottom right picture and it shows the 99-04 kit.... not as nice and it mounts realy low.
Old Mar 2, 2010 | 09:54 PM
RussB's Avatar
RussB
You might want to get this kit and run those stabilizers for a while and then you'll have the good brackets... when they wear out you can replace with some bilsteins if you care to do so...
Old Mar 2, 2010 | 09:56 PM
RussB's Avatar
RussB
Missed that... ! Nice catch ! That doesn't look half as good !
Old Mar 2, 2010 | 09:57 PM
WA.Ranger's Avatar
WA.Ranger
Duals are nice, but like Russ said, they get hurt. I know Rubicon Express relocates them above the axle with there lift kit, but I don't know if you can buy it separately. I really need to go over to there shop and see if I can find out cause I've been wanting to do that for awhile.
Old Mar 2, 2010 | 10:02 PM
WideOpenFord
i know! i was sitting there scratching my head sayin why is that so freakin cheap!
Old Mar 2, 2010 | 10:04 PM
WideOpenFord
oh wait never mind there both the same price. that makes no sence the 50-07 is way nicer!
blueh2o
Dec 7, 2014 10:57 PM
deadeyedevon
1978 - 1996 Big Bronco
15
Jan 4, 2010 06:12 PM
tetraruby
Nov 18, 2002 07:12 PM
Drawsoncad420
Jun 13, 2002 04:43 PM
Franklin2
Nov 22, 2001 07:41 AM
