Carbeurator problems.
Old Jan 21, 2003 | 06:12 PM
Andysutt's Avatar
Andysutt
My 66 F-100 is having carb problems.
I completely rebuilt it... including float.
It's still having the same problem. It'll run but then puke fuel out of the vent tubes in the top of the carb. I can give it a little gas and it quits doing this.
Is the float set to high or to low, or what?
If its not the float, what would it be?
Please let me know as I have never had this problem after doing a rebuild.
Old Jan 22, 2003 | 07:39 AM
44dwarf's Avatar
44dwarf
Your float level is to high. You'll have to bend the tab to lower it.
44
Old Jan 22, 2003 | 10:10 AM
Andysutt's Avatar
Andysutt
Thank you.
I figured it was the float, but I wanted to ask about it before I tear it apart again.
Old Jan 22, 2003 | 12:15 PM
cobraguy's Avatar
cobraguy
Andy also check your fuel pressure anything over 6 is too much.
Old Jan 22, 2003 | 01:13 PM
Andysutt's Avatar
Andysutt
I don't have any fancy tools at my house
so how could I check the fuel pressure?
It shouldn't be that high... just a stocker mechanical fuel pump
Any ideas on how to check it would be appreciated.
Also... it only over flows like at an idle... give it a bit of gas, it dont overflow... because it uses the fuel Im assuming.
Old Jan 22, 2003 | 01:27 PM
44dwarf's Avatar
44dwarf
Unless you've changed the pump right before you dug in to the carb, I'd say it's fine. You need a simple presure gauge to check it. Float height is the most likely problem as you said it stops when reved up, thus it's using the volume and not overfilling.
44
Old Jan 22, 2003 | 01:29 PM
Andysutt's Avatar
Andysutt
Hey,
Nope it's got the same pump on it that it's had for a while.
I'll adjust the float and let you know
I gotta redo some trans lines tho... some moron ran rubber lines ABOVE the exhaust manifold and they fell down onto the exhaust yesterday and burnt a hole thru it.
Now I gotta fix that before I can run the truck again.
Nice for people to do stuff the right way huh?
Old Jan 22, 2003 | 02:14 PM
44dwarf's Avatar
44dwarf
Andy.
Use steel 5/16 line it's right next to the brake line at the autoparts store. You'll need a good bender and most likely a couple of union fittings but the flare ends should fit right in to the rad and trany with no problems.
44
Old Jan 22, 2003 | 02:40 PM
Andysutt's Avatar
Andysutt
Thanks.
That's what I had planned on doing.
I was just going to spot repair that piece of hose with a piece of steel line and hose clamps. It only burnt about 3 inches out of it. I'll replace the full lines when I get the 460 built and ready to swap inplace of the 390
johnf3504x4
Dec 7, 2013 09:56 AM
sixshootingexp
Dec 2, 2012 10:30 AM
65CJ5
Apr 5, 2004 07:25 PM
ClatonK
Jan 4, 2004 11:20 PM
1970f2504x4
35
Dec 25, 2003 10:14 PM
