front rotor
Old Mar 2, 2010 | 03:33 PM
mxdad3's Avatar
mxdad3
front rotor
i've read all the post on how to get them off. mine looks like its held on by the axle bolt. has anyone heard of such a thing?
Old Mar 2, 2010 | 04:10 PM
ascali's Avatar
ascali
mine looks like that at beginning but it's actually 2 pieces together. I used a 6" 3jaws gear puller to take them off. take me 5 hours. it's pain, believe me.
Old Mar 2, 2010 | 05:11 PM
cbradford's Avatar
cbradford
2WD or 4WD???????
Old Mar 2, 2010 | 10:07 PM
Moto Mel's Avatar
Moto Mel
There is an excellent post on the subject somewhere on FTE. I suggest that you make a search. It is well worth the effort.
Old Mar 3, 2010 | 05:52 AM
broncoholic's Avatar
broncoholic
2WD or 4WD and model year would be very helpful. I used a 5 lb sledge with a 3 foot handle on my 03 4x4. A couple wacks on the corner of the hat section popped mine right off.
Old Mar 3, 2010 | 07:24 AM
mxdad3's Avatar
mxdad3
front roror 00 expidition
4x4.
it looks like the axle bolt holds it on but all the replacement rotors i looked at dont have that appearance
Old Mar 3, 2010 | 07:46 AM
jdecker's Avatar
jdecker
It's not held on by the bolt. I beat the heck out of mine before it finally come off, but there is a posting somewhere on this site I saw afterward with a pretty slick procedure for removing them.
Old Mar 3, 2010 | 07:49 AM
cbradford's Avatar
cbradford
4x4 once you remove the wheel and brake caliper/ bracket rotor should pop off, however they have been known to rust fast. Sometimes they will pop off with a BFH and others may need to be cut off.
Old Mar 3, 2010 | 08:39 AM
deanjet's Avatar
deanjet
Just in case you missed this;
VIDEO: Truck Brake Rotor Removal Made Simple (Seriously) .: Articles
Old Mar 3, 2010 | 08:48 AM
Moto Mel's Avatar
Moto Mel
Originally Posted by deanjet
THAT'S THE ONE!!!
Old Mar 3, 2010 | 09:06 AM
cbradford's Avatar
cbradford
This works great if not too rusted, tried with my 97 and had so much tension on caliper bracket thought it was gonna snap. Then took the sawzall to it and was off in 2min.
Old May 2, 2010 | 09:33 PM
lonewolf5557's Avatar
lonewolf5557
rotors rusted on help!!
I saw you said you took a sawzall and it popped right off. Where did you cut or what did you cut. I need major help. I have been trying the bolt throught the caliper bracket trick and NOTHING. It won't budge. I DO NOT remove the nut behind the dustcap, correct?? The guy at Autozone said yeah but I figured he had no idea what he was talking about. That is for the bearings, right??
Anyways please someone help I have no clue what to do next. This has been a 2 day project already and I'll be on day 3 tomorrow. Thanks all.
Old May 2, 2010 | 09:58 PM
alloro's Avatar
alloro
Dustcap? If you have a 2WD Expedition then yes, you need to remove the dustcap, the cotter pin, and then spin the center nut off. On 2WD models, the hub and rotor are one assembly.
Old May 2, 2010 | 10:03 PM
lonewolf5557
Siezed rotors
I actually have a 2wd Excursion. I know this was a Expidition post but I am trying to get help wherever I can get it.
Does this assembly removal apply to my Ex also?? Thanks.
Old May 2, 2010 | 11:55 PM
alloro's Avatar
alloro
Yes it does.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
